Brambo Calipers... what to use? which to keep? - Ducati.ms - The Ultimate Ducati Forum
Old Apr 11th, 2011, 2:26 pm   #1 (permalink)
lior_baruch's Avatar
Hi,
Looks like I got few spare Brambo calipers... (about 12...)
As per your knowledge and experience, which should I use for my project? (The SSD that's gonna look like SS )
I added pics below with some of the numbers on the calipers.
Thanks!
Lior.
Brambo Calipers... what to use? which to keep?-dsc03781.jpg   Brambo Calipers... what to use? which to keep?-dsc03782.jpg   Brambo Calipers... what to use? which to keep?-dsc03783.jpg   Brambo Calipers... what to use? which to keep?-dsc03784.jpg   Brambo Calipers... what to use? which to keep?-dsc03785.jpg
lior_baruch is offline   Reply With Quote
Old Apr 11th, 2011, 3:49 pm   #2 (permalink)
Bevel-Heaven's Avatar
HI Lior, I would pick the 3 that match that have the best piston bores. You will need obviously, 1 left and 2 rights for your bike. I prefer the dual bleed screw type as they are the old type as compared to the single bleed screw type which are newer [these single bleed screw types are available new stull FYI]. It doesn;t look like you have any of the 'shaved' type where there is no brembo logo and a narrower gap requiring shorter pins and thinner pads otherwise I would advise keeping those...... The newer black aluminim coated pistons are smoother / better then the chromed silver steel pistons too.
Ciao for now
Steve Allen
BevelHeaven.com ~ It's all about Moto Ducati
(925)798-BEVL[2385] ~ RIDE 'EM, DON'T HIDE 'EM
Bevel-Heaven is offline   Reply With Quote
Old Apr 11th, 2011, 9:03 pm   #3 (permalink)
Images: 3
Lior,
Are you having the calipers re-anodized?
Cal in Minnesota
1973 Ducati 750GT
1976 Moto Guzzi Le Mans
1976 BMW R90/6
1999 Ducati ST4
2004 BMW K1200RS
2005 BMW R1200ST
WindyDucat is offline   Reply With Quote
Old Apr 12th, 2011, 3:29 am   #4 (permalink)
Thanks Steve!
Originally Posted by WindyDucat View Post
Lior,
Hmm... I thought about just cleaning them, rebuilding and painting it back to black. Why should they be re-anodized?
Lior.
Old Apr 12th, 2011, 9:44 am   #5 (permalink)
Images: 3
Lior, anodized calipers will last much longer and will be "period correct", if that is a concern.
The key is finding an expert shop who knows what they are doing, if not, they can damage your calipers, especially the bores. I am restoring a 73 duc, and so far I have not found a shop that I trust to re-anodize my scarab caliper. Most finishing shops deal with new aluminum stock and have little if any experience with removing the old anodizing, polishing and then re-anodizing. If I can't find a shop that has a track record, I will paint them, but only the external surface area and stay away from the bores and internals.
Cheers! Cal
Cal in Minnesota
1973 Ducati 750GT
1976 BMW R90/6
1999 Ducati ST4
2004 BMW K1200RS
2005 BMW R1200ST
749 Calipers on 996 NoCompromise Superbikes 10 Aug 25th, 2010 9:47 pm
999 calipers f/s tlrider187 Parts and Accessories 3 Mar 16th, 2010 5:02 am
Calipers...2 Pad vs 4 Pad galaxy Superbikes 4 Dec 1st, 2008 7:13 pm
xx9 4 pad calipers fit 998? Dub-U! Superbikes 1 Jul 12th, 2008 10:56 am
998 Calipers - 2 pad vs 4 pad jules_1972 Superbikes 20 Jun 7th, 2006 9:23 pm
