Scrambler in my garage! - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Apr 7th, 2011, 11:48 am   #1 (permalink)
Chilehead
st2lemans's Avatar
Images: 74
Alas, it's not mine, I'm just fixing a few things for a friend.
So, suggestions for online sources for manuals and other info?
Also, the forks need new wipers, and I notice that Steve at Bevelheaven has two versions (early/late) for 35mm Marzocchi forks, so which is early, and which is late?
Thanks,
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Apr 7th, 2011, 8:41 pm   #2 (permalink)
748girl's Avatar
Manuals can be found at www.ducatimeccanica.com and some at loudbike - More vintage new original stock OEM and aftermarket Ducati parts than you can shake a stick at.
Loudbikestore also sells parts. You can search by description or part number.
748girl is offline   Reply With Quote
Old Sep 3rd, 2011, 6:26 pm   #3 (permalink)
day late and a dollar short?
Hey Tom:
Although it doesn't specifically cover SCRs, the Haynes manual is best for
wide case Ducs. The factory (readily available as reprint) and Clymer book
an be helpful, but it's the Haynes I usually turn to. Sacn the net stores and Ebay for all. Also Motoscrubs (just Google it) has free parts manuals online for reference for narrow and wide case model SCRs. Very handy.
You didn't say what SCR you have, but there are three basic kinds:
250 narrow case
250~450 wide case Series 1
250~450 wide case Series 2
Narrow case will be obvious (250s only, ugly, but has its own charm [had one years ago]). Series 1 has steel rims, full gaiters on front/rear suspension. Series 2 equiped with alloy rims, double-sided front /Grimica brake, dust cups only front on forks, open springs rear shocks.
If wide case, check out AMICI DELLO SCRAMBLER | Club Ufficiale Ducati Scrambler Rimini, Ricambi Ducati Scrambler Moto Epoca. Info you won't find anywhere else.
Hope this helps,
Cliff
vt450scr is offline   Reply With Quote
Old Sep 3rd, 2011, 8:08 pm   #4 (permalink)
Queestce's Avatar
Hey,
I have no insight on manuals or the like, but I am almost certain I speak for the masses when I say, PICS REQ'D!...
Tk
"You live more in five minutes on a bike like this going flat out than some people live in their lifetime." Burt Munro
06' Monster 620 | Termi's, DP Intake & ECU
84' Honda CT-110 | Bone stock - Never say die!
94' Kawasaki EL-250 | Divorced
04' Honda CT-110 | Divorced
89' Honda VT-250 | Deceased
Queestce is offline   Reply With Quote
Ducati scrambler kartagines Vintage 3 Oct 4th, 2009 12:26 am
70 450 scrambler DucmanST3 Vintage 17 Mar 29th, 2009 11:19 pm
250 Scrambler... dillon Vintage 7 Feb 14th, 2009 7:52 am
~ 1965 Scrambler 250 scramblinman Vintage 34 Nov 4th, 2007 3:04 pm
