What to do for resto? - Ducati.ms - The Ultimate Ducati Forum
Old Mar 23rd, 2011, 9:29 pm   #1 (permalink)
Im just gettignt he last things done for my cadet 100 resto, i found the correct carb, air filter, a NOS speedo, and getting it bored out a bit and re-plated fresh,
i have a few questions as its my first resto of a bike,
-How would it hold up if i got the chassis and evrything that needs to be black painted? is it cheaper than powder coating??
-Those decals you buy from ducati places, the mylar ones or w/e thier called, can i apply them on the bike where they need to be and then get the parts clear-coated with the decals on to seal them? or do i put them on last?
-is the clutch supposed to be hard to pull? like unusually hard as compared to a bike of today? i just want to make sure i assembled it right,
thats all i can think of ATM, once the motor gets back and i start assembly i will surley have more,
and just as a little bonus, can anyone tell me what kind of bars this guy has on his cadet?
they look to have a bit of a curve when they go forward then go straight out for the controls, i want them im gonna try to go for that sporty cafe look instead of those raised bars i have on there now
DreyeIce is offline   Reply With Quote
Old Mar 24th, 2011, 6:20 am   #2 (permalink)
Images: 79
Regarding decals, you can apply them before clear coat for durability or after. Same for pinstriping.
Paint done correctly will hold up fine. Here is a thread about it: Paint or Powdercoat?
There is a lot of info on the Old's Cool forum on advrider.com too.
These clutches are going to be harder then "modern" bikes with hydraulic clutches. Not sure when it is unusually hard.
marret is online now   Reply With Quote
Old Mar 24th, 2011, 7:04 am   #3 (permalink)
The clutch cable is the most likley cause of a hard clutch, but don't dismiss anything else.
GRM 450 is offline   Reply With Quote
Old Mar 24th, 2011, 7:36 pm   #4 (permalink)
sandman800ss's Avatar
The bar style on that Cadet are called "clubmans" and are readily available from many sources. They give you the position and look of clip-ons, but are cheaper and simpler. You are aware that you'll need to find shorter throttle, clutch, and front brake cables than stock as a consequence, right?
sandman800ss is offline   Reply With Quote
Old Mar 24th, 2011, 8:01 pm   #5 (permalink)
SP3
SP3's Avatar
Images: 6
When I did my Monza, I decided on powdercoat for the frame, swingarm an odd bit here and there. If I were to do it again, I'd just use paint. Looks more correct and just 'better' to me. And, if done properly, it is plenty durable. 3 cents for ya.
1991 851 SP3
1966 250 Monza
1999 Moster 900 City (not so much City anymore)
SP3 is online now   Reply With Quote
Old Mar 24th, 2011, 10:35 pm   #6 (permalink)
A gloss paint finish on the frame is not only more correct but looks million times better than powdercoat. Powderocat is too thick and lacks that crisp look only paint can give. If you ever saw the two side by side you would never powdercoat.
61 175 TS
73 750 Sport
74 750 Sport
74 750 GT
75 750 GT
75 750 SS
02 Foggy Monster
07 SC1000SportClassic with a sealed gas tank and some mods.
93 Superlight
04 Moto Guzzi V11 Sport
Streetfighter S with some mods and a sealed gas tank.
Scheming for a 1199TriColore
"Perfection is a worthwhile goal if you don't expect to achieve it"
TheDucnutOfBevelville is offline   Reply With Quote
Old Mar 25th, 2011, 1:48 am   #7 (permalink)
^^^agree^^^
Powdercoat has it's uses, but being as it's 40X as thick as paint, vintage frames are too big a surface for it- IF you value authenticity and originality in your restoration appearance. It looks way too thick and "plasticy" looking compared to paint.
Old Mar 27th, 2011, 1:30 pm   #8 (permalink)
well, im not going totally original on it, i know its not worth much anyways, i have all the stock parts, but im restoring and buying a few things different, like clubman bars,
i think i might just go with paint anyways, it just sounds easier too,
and i guess the clutch thing ,makes sense, the one i was thinking of compared to was a hydraulic clutch :0
im trying to take apart and clean the forks, on the cadet its like 3 slides, how do i get them apart?
Old Mar 28th, 2011, 1:09 pm   #9 (permalink)
Err, umm- you haven't obtained a shop or service manual for your project yet?
Old Mar 29th, 2011, 6:41 pm   #10 (permalink)
nope, cant find one, it sucks
resto 82 SS advice please shanetbird Vintage 27 Mar 15th, 2011 12:38 am
Duc 750 GT Resto Questions WindyDucat Vintage 5 Dec 31st, 2010 11:42 am
New 60's Monza Jr. 160 resto project DucatiMichael Vintage 33 Jun 7th, 2010 3:08 pm
resto on 82 SS tyres advice please shanetbird Vintage 3 Sep 26th, 2009 5:14 pm
996 Resto-Mod 2 in progress DT996 Superbikes 20 Jul 14th, 2007 12:46 am
