Mar 7th, 2011, 5:16 am
Darmah sprag clutch failure ?
I have a 1979 Dramah SD. Good condition, usually starts first time. For some reason she backfired & popped a lot this weekend. When she eventually fired, she made a noise like the starter motor was not disengaging & now the starter motor won't work : just goes "click" when I hit the button.
Seems like I have popked the sprag clutch.
Also seems like fixing is an issue.
Can anyone offer any advice (pref. step by step instructions !) or refer me to a good guide ?
'79 Darmah
'81 Le Mans
'09 GSA
5 bicycles
Mar 7th, 2011, 12:35 pm
Mar 8th, 2011, 8:54 am
Thanks
'79 Darmah
'81 Le Mans
'09 GSA
5 bicycles
Mar 8th, 2011, 6:24 pm
A click from the button indicates the solenoid is not triggering the starter motor. If the sprag was faulty the starter would still spin but not engage the motor, a very distinctive sound. Check the connections to the solenoid, the solenoid itself and the brushes in the starter motor. A very flat battery will also give a click. Darmah's require very strong batteries, so you may also need to check the charging system if you experience ongoing weak starting.
John
'97 916 Senna (Series III #037)
'98 ST4
'82 900SD Darmah
'82 600SL Pantah
'84 650SL Pantah
'03 800Sport (track bike)
Mar 9th, 2011, 12:33 am
Luckilly, I've never had to touch my sprag, but if I have to, how do I get the locking plate out of the back of the flywheel? it is punched into place and how is it fixed back in afterwards? Is it necessary to buy a new plate and punch it in again?
Mar 9th, 2011, 5:57 pm
I've ever had any issues with my sprags either , a good battery is the go and make sure you have a better earth than what is supplied with the bike.
If you sprag is buggered why would you bother with modding anything when you can get them for US$157 from BH
Bevel Heaven - Detail
Cheers Marty
Thanks Martin
SSD900
76 SS
Apr 8th, 2011, 6:51 am
Thanks for the help & references.
Turns out it was both the sprag & the starter motor. I assume the sprag went & this caused the engine to overrun the starter, which dropped a bush or something & destroyed the armature.
Anyone know where to source new starter motors ?! (I have fortunately found a second hand one)
'79 Darmah
'81 Le Mans
'09 GSA
5 bicycles
