Flywheel WILL NOT come off! - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 25th, 2010, 9:31 am   #1 (permalink)
I have a 100 cadet 2-stroke engine,
i bought the flywheel puller for it, the one that screws in and has a bolt for the middle, no matter how hard i get that bolt to crank down this flywheel will not budge,
i pulled out my Makita hammer-impact driver, put a socket on and gave it hell and it wont come off, then, when it was was on there good i hit the top of the puller a few times with a nice heavy hammer, still nothing!
any ideas or tricks? Thanks,
DreyeIce is offline   Reply With Quote
Old Nov 25th, 2010, 10:34 am   #2 (permalink)
With the end of the crank being twisted off, is the center bolt of the puller pressing on the flywheel? If it is you may have to make a spacer to go between what's left of the crank and the puller bolt. A fair amount of pressure and a quick whack on the center bolt should pop it right off.
wdietz186 is offline   Reply With Quote
Old Nov 25th, 2010, 3:56 pm   #3 (permalink)
i did make a spacer, i cut the body part off a grade 5 bolt, i used a few nuts earlier and they squished like nothing,
i gave it plenty of whacks, progressively harder each time, it wont come off!
Old Nov 25th, 2010, 6:18 pm   #4 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
If there was any thread lock on it you might want to try heating it with a torch first.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
va duc is online now   Reply With Quote
Old Nov 28th, 2010, 11:04 am   #5 (permalink)
rcrob's Avatar
Try and reposition the woodruff key with a small drift punch.
Use the puller to preload the flywheel, then apply heat to the flywheel you have to be careful though and try and limit the heat to the taper area of the flywheel. It is best if you have something like an oxy-acetylene torch which will put a lot of heat in quickly so you can get the flywheel to expand without also expanding the end of the crank. Be careful it might be a bit dramatic when it comes off though!
rcrob is offline   Reply With Quote
Old Nov 28th, 2010, 11:09 am   #6 (permalink)
Site Sponsor
ducatimike's Avatar
Use a little liquid wrench, install the puller and let it sit overnight. I have found this to work when gears are stuck on shafts. Applying heat is a good idea too.
Mike
99 ST4
05 Honda 450F
01 YZ 250
92 CR 500
www.emsduc.com
www.ducati-owners-group.com
ducatimike is offline   Reply With Quote
Old Nov 28th, 2010, 6:00 pm   #7 (permalink)
ok, i already had it sitting in liquid wrench for a few days, i kept re-coating to try and loosen it up, ill try heat,
i might go buy a bottle of MAPP gas, rather than propane, MAPP is about the hottest i have available atm
im just suprised how fused it is on there, wow...
Old Nov 29th, 2010, 7:07 am   #8 (permalink)
Penetrating oil
FWIW, in my experience, both Kroil and PB Blaster are much better than Liquid Wrench in freeing up stuck parts. Heat usually helps, though.
Good luck!
2002 ST2 (Yellow)
SwiftFF5 is offline   Reply With Quote
FS: 996 Flywheel Fishmonger Parts and Accessories 1 Jul 23rd, 2010 11:32 am
St3 Flywheel Nut fighterfire Sport Touring 7 Aug 5th, 2009 12:15 pm
Flywheel Keyboard Superbikes 1 Sep 18th, 2007 9:01 pm
Flywheel ????? icemetal900ss Supersport 3 Feb 6th, 2007 8:31 am
Flywheel for 999 999q8 Superbikes 3 Jan 8th, 2007 9:11 pm
