Clutchless shift on track - Ducati.ms - The Ultimate Ducati Forum
post #1 of 17 (permalink) Old Nov 11th, 2010, 12:59 am Thread Starter
michaelkei's Avatar
Hi, for those of you who use SF on track, do you shift your gear without using the clutch and without a quick shifter?
MichaelK
michaelkei is offline
post #2 of 17 (permalink) Old Nov 11th, 2010, 2:48 am
bzr
bzr's Avatar
Yes!
Mutli 1200 S
This page has had 1283 visits! Please stop!!!Seriously!!!!
bzr is offline
post #3 of 17 (permalink) Old Nov 11th, 2010, 4:07 am
Sputniks's Avatar
I always shift (on a street and track) without no clutch. But the bike does have a DP quick shifter.
Sputniks is offline
post #4 of 17 (permalink) Old Nov 11th, 2010, 5:32 am
indianfighter's Avatar
I do it on wheelies sometimes but have noticed if the up shift is not assertive it does at times goes into false neutrals.
Indianfighter Mumbai, India. The Past: 2009 Streetfighter 1098
The Present: 2015 HyperMotard, KX250F (MX), CBR1000RR track bike
indianfighter is offline
post #5 of 17 (permalink) Old Nov 11th, 2010, 8:04 am Thread Starter
michaelkei's Avatar
Thanks all. Will give it a go to see if it gain time on track, hopefully I won't damage the clutch and gearbox too much. May try a quick shifter if it is not too expensive
MichaelK
post #6 of 17 (permalink) Old Nov 11th, 2010, 10:58 am
Get the quick shift setup. It kills the ignition for a split second to break the torque, and that's easier on the shift dogs in the tranny.
'15 BMW R nine T
'09 Kaw Versys
ttpete is online now
post #7 of 17 (permalink) Old Nov 11th, 2010, 1:34 pm
shark wrangler
flynbulldog's Avatar
I upshift all the time (track and street) with no clutch - I've also used the QS and they are cool but I don't really see a need to spend the money.
Link to all of my bikes and builds: *Click!*
flynbulldog is offline
post #8 of 17 (permalink) Old Nov 11th, 2010, 2:31 pm
bzr
bzr's Avatar
....as the old schoolers shuffle on down pit lane muttering "we don't need no damn quickshifters"
Mutli 1200 S
bzr is offline
post #9 of 17 (permalink) Old Nov 11th, 2010, 3:15 pm
I don't deny that you can. But sooner or later it'll booger up the engagement dogs on the gears, and it'll start popping out of gear. Then you get to split the cases to replace them. That's acceptable with a race bike that gets pulled down every year, maybe not for a street bike. You can pay a little now or a lot later.
'15 BMW R nine T
'09 Kaw Versys
post #10 of 17 (permalink) Old Nov 11th, 2010, 6:59 pm
shark wrangler
the momentary ignition cut is no different than a quick throttle blip to release tension on the drive train...
Human Verification
best RPM to shift on track MMA MIA Superbikes 8 Sep 11th, 2008 10:05 am
what rpm should I shift 749 at track? ducduc Superbikes 14 Aug 14th, 2007 7:54 pm
Clutchless upshifting bromike666 Ducati Motorcycle Chat 12 Jun 19th, 2007 7:39 pm
Clutchless shifting?? st2brooke Ducati Motorcycle Chat 15 Feb 17th, 2007 11:36 am
Clutchless shifting Lars Supersport 8 Aug 12th, 2006 9:05 pm
