clutch problems - Ducati.ms - The Ultimate Ducati Forum
post #1 of 19 (permalink) Old Sep 23rd, 2010, 11:45 am Thread Starter
clutch problems
out for a ride yesterday, nothing extreme at all. about 2 hours into the ride on highway 1 the clutch lever gets really hard, meaning the lever can't be pulled in at all. i had to bump start it after i pulled over and hobbled to the closest town.
i got the bike towed to the shop, where i will find out whats up with the clutch.
concerns:
is bump starting your bike bad - can it damage the motor or gearbox?
what i learned you can only bump start the bike in second or third gear and you have to be rolling at least 10mph. i had to push the bike up 2 hills in order to be finally successful at starting it.
i have the yoyodyne clutch slave installed.
tech said initially that it was hydraulic lock?
anyone experience something like this?
vspinner is offline
post #2 of 19 (permalink) Old Sep 23rd, 2010, 11:55 am
Temporary greeter
Wonway's Avatar
What is a bump start?
Wonway is offline
post #3 of 19 (permalink) Old Sep 23rd, 2010, 1:13 pm
RetroSBK's Avatar
Questions...
why would you have to bump it? Is it stuck in gear? or when you pull the clutch in, it wont engage enough to make it so you can shift?
Typically, when you cant pull the lever in all the way, you have water in the system, and it has expanded and wont allow the piston to compress. This also usually means that the reservoir is too full, and is not allowing the expansion...
but im really curious why you have to bump it.
And no, bumping it wont hurt ANYTHING.... No different than starting a bike on rollers, etc
Will Kenefick's Retro Superbike - Building the sickest shit since 1994
Too much junk to list
RetroSBK is offline
post #4 of 19 (permalink) Old Sep 23rd, 2010, 2:13 pm Thread Starter
bump start
Originally Posted by RetroSBK View Post
Questions...
the clutch would not egage at all - so i had to bump start it in 2nd so that i could get going. the clutch lever was not functional at all. i could start it in neutral but shifting was no an option
vspinner is offline
post #5 of 19 (permalink) Old Sep 23rd, 2010, 2:15 pm Thread Starter
bump start or rolling start
Questions...
exactly the problem.
vspinner is offline
post #6 of 19 (permalink) Old Sep 23rd, 2010, 3:04 pm
MotoGreg's Avatar
Don't mean to be overly technical but just an FYI... The clutch is always engaged and transferring engine revolutions through to the transmission.
When you pull the lever you are disengaging it.
'10 Husqvarna SMR510
'10 Ducati Streetfighter
'06 Honda CRF450
And too many bicycles...
MotoGreg is offline
post #7 of 19 (permalink) Old Sep 23rd, 2010, 5:47 pm
Maximmagnum's Avatar
since you pushed it to the top of a hill anyway, what you could have done is start the bike in neutral and then get it going down the hill...when you got to 10 mph, THEN just put it into second gear without any gas on...should go (it'll be a bit rough) but you can then get to town...I'd only fiddle with bump starting if I had a dead battery...unless you do this constantly, you might not want to be too hard on your transmission, but one or two shifts like that won't kill it (as long as you don't have power on)
James
-White F1098 Streetfighter
Maximmagnum is offline
post #8 of 19 (permalink) Old Sep 24th, 2010, 12:07 am
Temporary greeter
Wonway's Avatar
Again...What is a bump start? Hitting it with an SUV?
Inquiring minds want to know!
Wonway is offline
post #9 of 19 (permalink) Old Sep 24th, 2010, 12:59 am
bzr
bzr's Avatar
It's a push start, nothing to do with SUV's or homo's.
Mutli 1200 S
This page has had 1283 visits! Please stop!!!Seriously!!!!
bzr is offline
post #10 of 19 (permalink) Old Sep 24th, 2010, 5:25 am
I've been upshifting w/o clutch for years and never had a problem.
Preload the shifter, let off the gas, upshift and the bike just snicks right into the next gear.
Spinner - seems like your problem stems from your clutch mod and not the SF
TallyRex is offline
Human Verification
Clutch problems Edgeofthewoods Ducati Motorcycle Chat 3 Sep 3rd, 2007 1:07 pm
ST2 Clutch Problems...Again Jeff423 Sport Touring 16 Mar 2nd, 2007 1:58 pm
Clutch Problems Team_Bob Superbikes 10 Aug 30th, 2006 3:10 pm
clutch problems ss 600 robbo74 Supersport 0 Jul 31st, 2006 10:17 pm
Clutch Problems spike6339 Superbikes 7 Jul 13th, 2006 8:01 pm
