Pirelli Diablo Corsa III or Diablo Rosso Corsa - Ducati.ms - The Ultimate Ducati Forum
Old Aug 12th, 2010, 10:26 pm   #1 (permalink)
The Engineer (Tell your mom hey)
blawrence's Avatar
according to JLM in this thread
DUCATI and the Swing Arm problem
Originally Posted by JLM View Post
Since Pirelli no longer produces the Corsa III tires that came stock with the Streetfighter, I went with Pirelli's recommended replacemant, the Rosso Corsa. The bike will be ready this Wednesday and I will be sure to check the clearance before I leave. The dealer still has Streetfighters with Corsa III's mounted, so I'll be able to compare the two.
As a side note, I rolled up to the dealer with just over 7700 miles on the Corsa III's. There was a strip down the center of the rear tire where the carcas was exposed. This strip was not present when I left for the dealer, 97miles earlier.
In hindsight, it was very irresponsible and dangerous to run the tires to this level of wear, but until compared against a new tire, I never really appreciated how little center tread remained. I won't make this mistake again.
however.. I can still find the corsa III tire on line for sale AND on the website. .. for the same price as the Diablo rosso corsa.... SO
is the guy right? are the corsa III's being discontinued? and even if they aren't..
as a vote .. which should I get? the III's or the rosso's?
I hang out here because of the girls.
xl1200x it's nice
blawrence is offline   Reply With Quote
Old Aug 12th, 2010, 11:04 pm   #2 (permalink)
Mr. One Touch
Wonway's Avatar
Shame on you BL. You should know by now that if your bike needs to be thrown away when the tires go bad. Don't install the Rosso's unless you want a major catastrophe.
Basically DUCATI recommend to use tyres originally supplied with the bike, but they forgot to mention the reason. Reason is that the swingarm has been designed only for a particular tyre DIABLO CORSA 3 190/55 and if you try to change with DIABLO ROSSO CORSA of the same size….bang…..when the tyre warm up it touch the internal part of the swing arm….even if Pirelli says the tyre is compatible.
Wonway is offline   Reply With Quote
Old Aug 13th, 2010, 3:53 am   #3 (permalink)
blackie's Avatar
A Swingarm designed for a tyre....What a crock of bollocks
http://www.ducatiworld.co.uk
blackie is offline   Reply With Quote
Old Aug 13th, 2010, 11:42 am   #4 (permalink)
blawrence's Avatar
tell me about it.. I bet a shop hammer to the inside of the swing arm would take care any 'interference
SO .. hopefully somebody will know... If I buy the Rosso Corsas and the 14 t bit that I've been meaning to get for a while .. and rotate the hub backwards to keep the chain tensioned .. will it all work great or will I just have to do it and try it?
NM.. I am reading more of the other thread I linked above.. dumb noobs always asking questions that've been answered
xl1200x it's nice
Old Aug 13th, 2010, 2:13 pm   #5 (permalink)
The September issue of Motorcyclist confirms the Corsa IIIs are being discontinued and being replaced by the Rosso Corsas. According to the mag, the Rossos are better in every way. I await reviews on this forum.
I just put on a new Corsa III last week with no problems ordering one. I still have a Corsa III up front so that is why I went with another out back. Next tire change will be Rossos front and rear. Though that rumor about the swingarm freaks me out, I have a hard time believing it. That would just be horrendous negligence.
What does concern me is that the DCT on the S was specifically tuned for the Corsa IIIs. (I think this conversation has been done before, but warrants another look). How will Ducati address this?
2010 Ducati Streetfighter
2005 HD 1200XLC (RIP)
knave is offline   Reply With Quote
Old Aug 13th, 2010, 9:29 pm   #6 (permalink)
flynbulldog's Avatar
The same way they addressed the fueling issue...
08 1098R
11 Multistrada 1200
10 Streetfighter S
89 GB500
77 KZ1000A
73 Duc GT750
74 Duc 750 sport special
66 Duc 250 NC racer
65 Norton Atlas cafe'
13 KTM 300 XC-W
Link to my book --> Backstory
flynbulldog is offline   Reply With Quote
Old Aug 14th, 2010, 1:10 am   #7 (permalink)
blawrence's Avatar
well I've ordered the new rosso corsas and a 14 t sprocket.. so in a few weeks I will be trying all this good stuff out. ... oh how the money goes away so quickly with this bike
xl1200x it's nice
Old Aug 14th, 2010, 2:25 pm   #8 (permalink)
Maximmagnum's Avatar
hahahaha
You are funny flyn
James
-White F1098 Streetfighter
Maximmagnum is offline   Reply With Quote
Old Aug 15th, 2010, 11:29 am   #9 (permalink)
JLM
The Rosso Corsa rear tire mounted on my S with stock 15t sprocket has about 5mm of clearance between the tire and swingarm. None of the other bikes at the dealer, fitted with Corsa IIIs, had more than 7 to 8mm of clearance. It's tight but after a few hundred miles, there are no obvious interference issues.
Interesting note, the mechanic put 39psi in both front and rear (I had been running 36psi with the III's); thinks it's arbitrary or related to the 5mm of clearance?
JLM is offline   Reply With Quote
Old Aug 16th, 2010, 3:13 am   #10 (permalink)
blackie's Avatar
39 front & rear
Fuck me you may as well put some stagecoach wheels & tyres on...
Pirelli Diablo Rosso Corsa Tyres blackie StreetFighter 38 Jul 26th, 2010 11:26 pm
Pirelli Diablo Rosso Corsa tires itofigari Superbikes 12 Mar 12th, 2010 11:29 pm
Corsa III replaced by Diablo Corsa Rosso Red-line Ducati Motorcycle Chat 4 Jan 19th, 2010 5:32 pm
Pirelli Corsa Diablo III BeHyper HyperMotard 22 Aug 21st, 2009 6:21 pm
Pirelli Diablo Corsa III mbohn Superbikes 20 Jul 7th, 2007 8:38 am
