Post light switch and dash software upgrade - am I going nuts? - Ducati.ms - The Ultimate Ducati Forum
Graves MotorsportsMotorcycle.com Classifieds!SportbikeTrackGear
Old Jul 21st, 2010, 7:02 pm   #1 (permalink)
mmoore's Avatar
Question Post light switch and dash software upgrade - am I going nuts?
OK, I got the light switch replaced per recall, and apparently also needed a dash software update (#09-09079).
All easy-peasy but then I tried to reset the trip meter at the gas station. Prior to the software update, all I had to do was hold in the center button on the turn signal switch for a few seconds. Post-update this does nothing.
I call the shop and they say you have to hold the top switch on the cluster in while pressing the center button. Huh? Well, OK, it works.
Am I going nuts? Was I doing it wrong all along?
PS - after the software upgrade, the DTC was set to off and I did a nice big wheelie getting on the freeway. Good thing no CHPs nearby!
2010 Streetfighter S; 2000 Monster 900; 2008 Vespa GTS
mmoore is offline   Reply With Quote
Old Jul 21st, 2010, 7:23 pm   #2 (permalink)
Mr. One Touch
Wonway's Avatar
You would have known if you checked the FAQ.
Streetfighter Answers, Solutions and Frequently Asked Questions
Wonway is offline   Reply With Quote
Old Jul 21st, 2010, 8:39 pm   #3 (permalink)
mmoore's Avatar
Ah, well OK then. Thanks for the info.
When I asked the service guy what the dash software update actually did, he said, "Ah, it's kind of like a reset. An update." Which didn't lead me to expect any functional changes.
So I checked the FAQ (this time) and there's nothing I can find on this dash software update. Anyone know what it's supposed to do?
Old Jul 21st, 2010, 8:55 pm   #4 (permalink)
Gilly's Avatar
Images: 18
I wonder what is up with the change? I realize that it is a "smart" dash that is able to re-purpose switches depending on what the function menu is set to. Is there an issue with the turn signal cancel button logic?
One thing that I would have rather liked is a dash similar in function to the 848evo (I could not find 1198 dash pics on the ducati site, but they list the same specs) We have to toggle to see time/trip/air temp. The superbike dash shows everything all at once so you don't have to play with the damn switches.
It would be nice if you could swap out our dash for that, but of course only if you knew the pin outs were the same on the harness and if the you had the immobilizer disabled like if you were running a MicroTec. Granted the dash is probably wider, wouldn't be a plug n play without a bit of work either integrating it or replacing the whole nose with another head light.... Just thinkin out loud.
2010 SF-S FFS, "Disremembered"
Old Jul 21st, 2010, 9:03 pm   #5 (permalink)
Yeah that looks nice... I bet they give those away!!
iguanamafia is offline   Reply With Quote
Old Jul 23rd, 2010, 12:59 pm   #6 (permalink)
achung123's Avatar
I will do the recall fix tomorrow too... I still don't know that's the real issue behind this recall - but I did find that it is hard to cancel the signal. I have to really press on it a few time before it goes off....
achung123 is offline   Reply With Quote
Old Jul 23rd, 2010, 2:25 pm   #7 (permalink)
Oahu_fighter_pilot's Avatar
I got a new dash with the new mileage reset function at 1k miles and it didn't change the turn signal cancel effort at all...it still takes a conscientous push...
-2010 White Streetfighter...my drug of choice, my escape from reality...
-gettin' old ain't for wimps...
Oahu_fighter_pilot is online now   Reply With Quote
dash light brightness duc dude Supersport 7 Oct 24th, 2008 3:27 pm
can't post using firefox since new look upgrade KoiHoshi Ducati.ms Site Help, Feedback and Suggestion 2 Jan 17th, 2008 3:24 am
1098 red flashing dash light zsnnf Superbikes 8 Apr 19th, 2007 12:12 am
front sprocket/light on dash/rev light for 998 donno Superbikes 7 Jul 12th, 2006 3:13 am
