Wobble In Left Hand Turns - Ducati.ms - The Ultimate Ducati Forum
post #1 of 18 (permalink) Old Jul 22nd, 2015, 8:59 am Thread Starter
My 2012 SFS bought new in 2013 with 7700 miles seems to wobble or get mild head-shake in high speed left hand sweepers. Any clues to why?
I can only think it could be tires or suspension. My tires are BT003RS with lots of tread, could they come out of balance?
It did roll off its kickstand a year ago on a lumpy driveway on the left side but only damaged the CRG mirror, scuffed the foot peg and put a tiny scratch on the water pump - that's all.
I hope I can sort this out it is kind of scary.
Any ideas?
2012 SFS
2014 BMW GS800 Adventure
FTB
C Smasher is offline
post #2 of 18 (permalink) Old Jul 22nd, 2015, 9:21 am
mojodog's Avatar
Try to realign the forks. If you search you can find the procedure .
2010 SF, 2011 M796- wife's
A few other and many gone and still missed
mojodog is offline
post #3 of 18 (permalink) Old Jul 22nd, 2015, 9:22 am Thread Starter
I will research that. Thanks.
2012 SFS
FTB
post #4 of 18 (permalink) Old Jul 22nd, 2015, 10:48 am
Old Wizard
Shazaam's Avatar
If you dont follow the proper installation sequence for the front wheel, you can incorrectly align the front axle in the forks which will cause unwanted friction in the fork tubes and handling oddities.
You can use a dowel inserted from the left side to hold the wheel in position. Put anti-seize or grease on the axle and then insert it from the right side (of the bike). To avoid damaging the thin-walled axle, tap it in gently and rotate it using the special tool from your Ducati tool kit. Once it is in, line up the holes in the axle with the holes in the axle clamps so that the through-holes allow screwdriver access to the compression valve adjusters.
The common mistake made here is to just tighten everything up at this point. Instead, heres the proper sequence to assure that the forks are aligned.
Temporally tighten-up the two RIGHT side axle clamp bolts so you can torque the axle nut.
Put on the (left side) 28 mm axle nut and torque it (63 Nm).
Then torque the two LEFT side clamp bolts (19 Nm).
Now, put the brake calipers back on using the proper torque setting (43 Nm).
Now, loosen the two RIGHT side clamp bolts.
Take the bike off the paddock stand, and bounce the suspension up and down till you are sure that the right side fork has moved to the proper (neutral) position along the axle.
Once this is done, torque the two RIGHT side clamp bolts to 19 Nm, reconnect the speedometer cable, and youre done.
Shazaam is offline
post #5 of 18 (permalink) Old Jul 22nd, 2015, 11:47 am
are both fork settings the same?
2010 Streetfighter S, Full Termi
2008 hypermotard 1100, 2-1 Termi, Aviacompositi tail, Sato RS-SOLD
-ftp- is offline
post #6 of 18 (permalink) Old Jul 22nd, 2015, 11:52 am Thread Starter
Thanks! I will check this out
I have never adjusted the suspension on this bike so I think so...
2012 SFS
FTB
post #7 of 18 (permalink) Old Jul 22nd, 2015, 4:23 pm Thread Starter
I found this page, lots of good leads.
Diagnosing Steering Wobbles Bareass Choppers Motorcycle Tech Pages
I do not have a lot of time this week to diagnose but I will keep you posted.
2012 SFS
FTB
post #8 of 18 (permalink) Old Jul 22nd, 2015, 11:59 pm
Ricko's Avatar
So you're telling me you have an SFS and never touched the factory settings for the forks and shock ?
You need to work this, first correct sag.
Then you would be surprised how many bikes leave the factory with forks compression and rebound not adjusted the same. Verify.
Align forks
If the above doesn't do the trick i put my bet on the tire.
And i still doesn't get the point of paying more for ohlins stuff just to leave it alone, and not adjust/dial it for YOU.
Macs are like Harleys... For wannabe different people, who get all the same sh!t
Ricko is offline
post #9 of 18 (permalink) Old Jul 23rd, 2015, 11:51 am Thread Starter
Align forks
I agree.
2012 SFS
FTB
post #10 of 18 (permalink) Old Jul 23rd, 2015, 12:09 pm Thread Starter
I had a chance to look at it last night. I found the left fork has moved up in the triple tree.
I will adjust this tomorrow, hopefully it will be settled.
Does anyone know if I should bring the left fork down or the right fork up? My service manual is at home.
Name:	Left Bottom.jpg
ID:	582938   Click image for larger version
Name:	Right Bottom.jpg
ID:	582946   Click image for larger version
ID:	582954   Click image for larger version
2012 SFS
FTB
Human Verification
Headlight: Left-hand vs right-hand drive K1W1 Sport Classic 15 Sep 22nd, 2011 10:23 pm
Right hand turns metalhead Road Racing 20 Jul 29th, 2009 3:23 pm
Lean more on right turns than left turns. hawc Superbikes 15 Jul 27th, 2008 9:29 pm
