Disabling the exhaust flapper without a cell. - Ducati.ms - The Ultimate Ducati Forum
post #1 of 18 (permalink) Old Nov 4th, 2012, 3:50 pm Thread Starter
Secret Squirrel's Avatar
I have read the Faq but I'm still unsure about how to do this. All I wan't to do is disable the flapper valve in the exhaust. I have a stock ecu and I don't really care about removing the servo and cable for weight reduction. I know I can't disconnect the electrical connection without throwing a cell. Is it possible to leave the servo motor plugged in and just disconnect the cable at one end without throwing a cell? If so which end of the cable is better to disconnect? At the servo motor or on the exhaust? I'm trying to do this the cheapest way possible. I know I can do this by installing a Duc.ee but is it needed if I leave the servo motor in and connected and just disconnect the cable? Does the SFS do the same servo check/sweep as the 1098 when you turn the key on? From reading I already know you can't just disconnect the cable on the 1098 without a cell. You need a stopper plate on servo to prevent a cell. I appreciate any information about this or links.
2011 Ducati Streetfighter S -- 2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
Secret Squirrel is offline
post #2 of 18 (permalink) Old Nov 4th, 2012, 4:20 pm
Hi. Are you doing this to smooth out your lower rpm a little, and/or make the bike a little louder at low rpm? Is there another benefit I don't know about?
proheli is online now
post #3 of 18 (permalink) Old Nov 4th, 2012, 4:23 pm
From what I understand if you remove the cables from the motor it still scans for stops but a small plate that Chris at desmoworld in germany sells to fit on the motor takes the place and fools the ECU.
mr shifter is offline
post #4 of 18 (permalink) Old Nov 4th, 2012, 4:37 pm Thread Starter
Both of those reasons. My bike is pretty smooth on the bottom end with the minimal fuel correction I have done. I'm pretty lucky. I'm still using the 02 sensors but have the AFR richened from stock. I wan't to eliminate the bike making additional unneeded fuel correction around the exhaust flap. I'm hoping that by disabling the flap I might gain an even smoother bottom end. My SFS already sounds good with the slip ons I have but if the sound increases a bit that's fine to.
post #5 of 18 (permalink) Old Nov 4th, 2012, 4:52 pm Thread Starter
I found the plate you where talking about. So the SF is like the 1098/1198 as far as the servo doing a check for the cable at startup. Have you ordered from Desmoworld before? All the prices are in Euros and in German language and I don't see a conversion to USD. I think I'm going to just go with the Duc.ee to get the job done. I know I won't have a problem getting one from Vizible Technologies. Then if I ever decide to take the servo out I can. Here's that plate from Desmoworld just in case someone else is interested.
Anschlag Bleck für Ducati Klappenmotor
post #6 of 18 (permalink) Old Nov 4th, 2012, 7:48 pm
darrenSF1098's Avatar
i disconnected the cable from the flapper end...just that...no CEL..
darrenSF1098 is offline
post #7 of 18 (permalink) Old Nov 4th, 2012, 7:52 pm Thread Starter
Thanks. Maybe I'll try that. I won't really know until the spring if it works when I can ride again.
post #8 of 18 (permalink) Old Nov 4th, 2012, 8:02 pm
Temporary greeter
Wonway's Avatar
As said, you can remove the cable from the servo and not get a light. You do need to leave the power connected to the servo.
Duc.ee is the way to go or just turn the servo off in your ECU with a tune.
1994 888 LTD #61 DVT
2014 KTM Adventure R with duct tape mod v1.0
Ducati.ms ECM photos
Wonway is offline
post #9 of 18 (permalink) Old Nov 4th, 2012, 8:25 pm Thread Starter
Do you recommend disconnecting the cable at the servo or down on the exhaust at the flapper to not have a cell come on? Or does it even matter which end of the cable is disconnected as long as you leave the power connector plugged in?
post #10 of 18 (permalink) Old Nov 4th, 2012, 8:32 pm
Temporary greeter
Wonway's Avatar
It don't matter.
Wonway is offline
Human Verification
exhaust flapper valve removal ... johnchypermotard HyperMotard 42 Aug 31st, 2015 3:45 am
exhaust flapper valve issue dieselquads StreetFighter 4 May 11th, 2012 8:09 pm
Disabling the exhaust valve Drinky HyperMotard 25 Dec 14th, 2011 3:29 pm
Eliminating code after disabling flapper valve... Brainfry HyperMotard 8 Apr 8th, 2008 3:19 am
pic of exhaust flapper disconnect yota HyperMotard 22 Feb 20th, 2008 10:35 pm
