New Streetfighter 848 Introduction and Question - Page 3 - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 16th, 2012, 12:36 pm   #21 (permalink)
Originally Posted by Wonway View Post
You guys shouldn't need to hold the throttle open. First thing to do is remove the vapor canister. And secondly, if you have an aftermarket exhaust on the bike, make sure it is tuned for it. If you still have problems, find them and fix them!
The vapor canister, finally, where is it on the SF848. I've removed it on all m other bikes, but need some pictures to show me what parts to remove from the SF848 engine.
Sent from my iPad using Motorcycle
aschemkes is offline   Reply With Quote
Old Aug 16th, 2012, 12:48 pm   #22 (permalink)
On the left side just above the horn. Pull the hoses and take it off. Plug the hose going to the throttle bodies and extend the tank vent hose. Now you have a nice spot to hang a better horn/s.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is online now   Reply With Quote
Old Aug 16th, 2012, 4:17 pm   #23 (permalink)
Sorry was talkin bout something different. I misunderstood you.
Old Aug 16th, 2012, 5:15 pm   #24 (permalink)
2Girls1SF's Avatar
my bike is completely stock and has 630 miles. i plan on asking the dealer when i take it in for the first service. it's only happened twice, but pretty much same scenario both times. getting off work, bike wouldn't start after sitting in the sun all day.
2Girls1SF is online now   Reply With Quote
Old Aug 16th, 2012, 10:49 pm   #25 (permalink)
rarely down, never out
3-stroke's Avatar
You can test the theory of the evap can with less than two minutes work, just locate the line coming from intakes to the canister (connects to top of canister, only one line since it tees into both intakes) pull it loose and temporarily plug it.
If it works, proceed with the full removal, if not stick it back on the can and let the dealership look at the bike.
The Director of the NSA walks into a bar and the bartender says "I've got a good joke for ya".......the Director cuts him off and says ".....heard it....."
Current rides:
'12 848SF
Husky 610 'tard
'04 R1
'01 ZX7R (too fat to fly)
'83 KZ1000ELR
'74 RD400 Daytona
3-stroke is offline   Reply With Quote
Old Aug 17th, 2012, 12:28 am   #26 (permalink)
I will give this a try next time it happens.
Roman
rlysecky is offline   Reply With Quote
Old Aug 19th, 2012, 7:37 pm   #27 (permalink)
Quick follow up for those experiencing this problem. I got back from a ride to day and parked the bike in the garage (temperature in garage is about 105F). Waited about 40 minutes and tried to start the bike. As before it started up briefly but immediately died. As suggested by 3-stroke and Wonway, I disconnected the evap canister and plugged the hose coming from the throttle body. And, bingo! Bike started up immediately, no need to hold the throttle.
Big Thanks Everyone!!
One quick question though. I extended the hose coming from the fuel tank (the larger of the two hoses) and routed it alongside some existing hoses that end just behind the bottom radiator (hope this description was clear). Is this a safe place to route the hose? It seems safe, but I just wanted to double check.
Thanks again,
Roman
Old Aug 19th, 2012, 7:41 pm   #28 (permalink)
Banned
Wonway's Avatar
Thanks again,
Roman
That should be fine. Glad it worked for you and thanks for the update!
Wonway is offline   Reply With Quote
Looked at used Streetfighter: purchase question georgere StreetFighter 31 Feb 7th, 2012 2:46 am
Streetfighter Question sobs384 StreetFighter 4 Jul 4th, 2011 12:05 pm
Streetfighter question.. Help sobs384 StreetFighter 20 Apr 6th, 2011 4:56 pm
My introduction / Gauge cluster warning lights question RollinVibe Monster 7 Jan 8th, 2008 8:49 pm
Introduction and Question 1527 Sport Touring 8 Oct 15th, 2007 8:39 pm
