Valve clearance check - how often do they need actual shimming? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 17 (permalink) Old Apr 20th, 2012, 7:18 am Thread Starter
samw5's Avatar
Just out of curiosity, factory calls for valve clearance check every 7500mi. I was wondering how often they actually do require to be shimmed on average.
2003 Suzuki SV650n (track/street beater)
2010 SF Tricolore
samw5 is offline
post #2 of 17 (permalink) Old Apr 20th, 2012, 7:31 am
BklynDuc's Avatar
I asked the same thing to a very experienced tech.
He said that generally, on the testastretta heads, if the clearances were set up correctly at the factory, then they are most times still within spec at 7,500 miles (unless it's a track bike or really beaten on).
That being said, my clearances on the horizontal head were all within spec.
The vertical cylinder was all over the place.
I ride with spirit at times, but I don't beat my bike, nor have I tracked this one yet.
2010 Black Streetfighter S
2000 996 S #267
A bunch of old ones
BklynDuc is online now
post #3 of 17 (permalink) Old Apr 20th, 2012, 7:33 am Thread Starter
samw5's Avatar
Do you recall if the price of the service was the same for shimming the vertical valves?
Looking at the service manual the job appears to be significantly more involved if shims need to be added.
2010 SF Tricolore
samw5 is offline
post #4 of 17 (permalink) Old Apr 20th, 2012, 7:53 am
BklynDuc's Avatar
I don't know. I did it myself.
I guess it would cost more because of the added shop time.
2000 996 S #267
A bunch of old ones
post #5 of 17 (permalink) Old Apr 20th, 2012, 7:55 am Thread Starter
samw5's Avatar
The heads need to come off to shim them right?
2010 SF Tricolore
samw5 is offline
post #6 of 17 (permalink) Old Apr 20th, 2012, 8:56 am
BklynDuc's Avatar
No. Just the valve covers, cam journals and cams.
2000 996 S #267
A bunch of old ones
post #7 of 17 (permalink) Old Apr 20th, 2012, 9:14 am Thread Starter
samw5's Avatar
Ah. I guess that gets me a little more confident I can do it. I guess I'll have to see how much free time I get this winter season
Thanks for the tip.
2010 SF Tricolore
samw5 is offline
post #8 of 17 (permalink) Old Apr 20th, 2012, 9:04 pm
BklynDuc's Avatar
Thanks for the tip.
Definitely a job you won't want to rush through.
Being my first time with a Desmo head,
It took me several days to do it with any amount of confidence in my work.
Even so, I decided to button everything back up and run it for another 1,000 miles, and I will recheck it all again. Just want to see how the half-rings/collets settle in etc.
I will do a write-up with pics of the process when I am satisfied with my work.
Probably won't be for a few months though.
2000 996 S #267
A bunch of old ones
post #9 of 17 (permalink) Old Apr 21st, 2012, 12:07 pm Thread Starter
samw5's Avatar
Ya definitely gonna take my time if I decide to do it. I'll have all winter so I'm not too worried.
2010 SF Tricolore
samw5 is offline
post #10 of 17 (permalink) Old Apr 28th, 2012, 9:03 am Thread Starter
samw5's Avatar
Did you guys also do the valve lift check when checking for valve clearance? Seems to be in the same section in the user manual so I'm not sure if that's part of the regular 7500 check.
2010 SF Tricolore
samw5 is offline
Human Verification
First time valve clearance check Mister E Supersport 5 Jan 13th, 2010 7:33 pm
Cam lobe position for valve clearance check WAP Superbikes 13 Nov 2nd, 2008 6:29 am
valve shimming questions jimmy98 Superbikes 14 Sep 29th, 2008 11:32 am
999 owners with Leo Exhaust, check your clearance! 2fasst Superbikes 3 Oct 8th, 2007 6:20 pm
6K Valve clearance check / adjust cost for 748? unicron Superbikes 3 Sep 5th, 2007 11:07 am
