Corse Specs - Ducati.ms - The Ultimate Ducati Forum
Old Feb 14th, 2012, 11:12 pm   #1 (permalink)
Sputniks's Avatar
Corse Specs
Ducati very special limited edition superbikes inherit a sexy term "Corse" to their model name : 1098 R Troy Bayliss Limited Edition or 1198R Corse Special Edition.
Some performance shops while describing their engine services often use a term "Corse specification". For instance here is what posted on ducashop.com:
"...When you get a street bike from Ducati it is assembled with very tight clearances so it is more likely to spin a rod bearing or wear other parts prematurely. Blueprinting will set the clearances closer to Corse specs as well as ideal cam timing..."
The question is what are the Corse Specs in a first place? Is information on this subject freely available? Are there any known online resources or some printed publications? When Ducshop says they set the clearances "closer" to Corse specs where do they get those specs numbers? And why do they set the clearances "closer to" and not "exact to" Corse specs?
Sputniks is online now   Reply With Quote
Old Feb 14th, 2012, 11:28 pm   #2 (permalink)
Mr. One Touch
Wonway's Avatar
The service manual of Corse.
Wonway is offline   Reply With Quote
Old Feb 14th, 2012, 11:45 pm   #3 (permalink)
Sputniks's Avatar
Brilliant!
1098R Of Corse Limited Edition
Old Feb 15th, 2012, 12:45 am   #4 (permalink)
unless they start to machine some stuff, bearings and shims only come in set increments and it may not be possible with the factory parts to bring it exactly into the tolerance range spec by the whoever comes up with the "corse" specs. When you blueprint an engine for racing the tolerance gets bumped up an extra 0 at the end usually cut in half.
All they are doing is blueprinting an engine and calling it by an italian name.
point45 is offline   Reply With Quote
Old Feb 15th, 2012, 12:53 am   #5 (permalink)
Sputniks's Avatar
Some would say Ducshop is just trying to help the ducati community get a perfect engine tuning.
Old Feb 15th, 2012, 12:55 am   #6 (permalink)
Mr. One Touch
Wonway's Avatar
Lol!
Old Feb 15th, 2012, 12:58 am   #7 (permalink)
yea you can say that also, but it dosent change the fact that they are blueprinting an engine.
Any good engine shop that supports racers running the ducati engine will be able to do the same.
And there is no such thing as perfect when it comes to tuning, theres best for the conditions.
999 specs 03redduc Superbikes 1 Dec 14th, 2011 11:25 pm
Cam Specs EIGHTfortyEIGHT Sport Classic 1 May 11th, 2010 11:25 am
torque specs superhawk Superbikes 1 Mar 13th, 2009 10:28 am
HM Specs and Info SouthsideDuc HyperMotard 8 May 4th, 2007 10:58 am
cam specs blade625CT Sport Touring 2 Oct 10th, 2006 9:36 pm
