Horsepower with Double-Dog exhaust - Ducati.ms - The Ultimate Ducati Forum
Old Jan 30th, 2012, 1:35 pm   #1 (permalink)
I know this is probably already been answered in here before, but I searched and couldnt find a direct anwser. So heres the dilemma:
My 10' SF-S has a Double dog exhaust installed, but no tune. So I had a local dealer do 3 dyno runs to see where it stands. So I wonna know what others with the same exhaust are making on their bikes. Remember, this is stock ecu, with no tune.
So now, I am lost as what to do next:
either get a Microtek, power commander, or reflash the ecu 1st. I dont know where to begin. Oh, and I guess the exhaust has the two bungs in the same pipe, so I need to install a bung in the other pipe, and close off 1 of the previous ones. Tuner said, it must be done, in order to tune properly. Sound right? help me out here guys.
2010 Streetfighter S
komodo is offline   Reply With Quote
Old Jan 30th, 2012, 2:20 pm   #2 (permalink)
IHMC Est. 2010
freezerburn's Avatar
Sputnikz will reply with a similar experience. Don't think an airbox, or throttle bodies will help... I think the DD guys use Nemesis and am sure you could get a map from them if you went the same route.
F1098S 'F' is for 'freezerburn', 'S' is for 'sick'
freezerburn is online now   Reply With Quote
Old Jan 30th, 2012, 4:56 pm   #3 (permalink)
I dont think a nemesis map will help me. I have to fix the common fueling issue at 2000-3500rpm, and then tune the bike for this exhaust. Look at 7k rpm, and how the torque dramatically cuts off. Its almost like the engine is cutting off the fuel at that point.
Old Jan 30th, 2012, 5:30 pm   #4 (permalink)
Sexy in '75!
3-stroke's Avatar
What FB is suggesting is that you get a Nemesis ECU and then use the map from Double-Dog...........it will undoubtedly help with both your 7K flat spot and your peak numbers.
It would still be best to do a few more dyno runs to fine tune it, but even without that I'd bet you'll see noticeable improvement.
Current rides:
'12 848SF (Imagine for a moment that Dragons were real, then imagine that Angelina Jolie loved one.......this would be their spawn)
'04 R1 (Sunday solo trips)
'01 ZX7R (Daily Driver)
'83 KZ1000ELR (mid-resto)
'74 RD400 Daytona
3-stroke is offline   Reply With Quote
Old Jan 30th, 2012, 6:54 pm   #5 (permalink)
I can help with this I am at another dealer in the eastside and I have this same set up. Don't use DDs map it is crap and hard to tune. Pm you email and I can get ahold of you Tuesday and give you some direction.
White '10 StreetFighter loud with carbon.
98043
nikoniko is offline   Reply With Quote
Old Jan 30th, 2012, 8:08 pm   #6 (permalink)
Sputniks's Avatar
128 HPs - it is exactly what it was after DD exhaust was installed and before the Power Commander map was re-tuned.
The remapping recovered almost 12 "lost" HPs bringing the power output to almost 140 HPs. Still the resulted power was significantly less than what it was with Termi full exhaust system (by the way DD claims almost 10 additional HPs over the full exhaust).
I think getting 12 HPs back just from remapping is a huge. I can't imagine it would be possible to get 20 or 30 or even 40 HPs just by using Nemesis or other map... unfortunately.
Sputniks is offline   Reply With Quote
Old Jan 31st, 2012, 11:43 am   #7 (permalink)
I know you said the deaaler had no answer but any chance of sending an email or putting in a call to DD to see what they recommend for getting the numbers they advertise?
2010 Streetfighter
2004 SV650
2002 VTR1000
MinuteMan is offline   Reply With Quote
Old Jan 31st, 2012, 2:10 pm   #8 (permalink)
jdurward's Avatar
how many miles on the bike? I had a top end problem due to a plugged fuel filter...
jdurward is offline   Reply With Quote
Old Jan 31st, 2012, 11:41 pm   #9 (permalink)
michaelkei's Avatar
I suppose if you follow DD's recommendation, you should be able to get what they advertise for, which is pretty impressive (althought the numbers don't quite line up with the chart ). I would choose DD over Termi just beacasue of the looks too.
There was also a thread talking about SF getting over 160~180 at the back wheel, I am still not sure how they are done as I can't find any more special engine performance/racing parts for Streetfighter, which is a shame as I am keen to turn my SF into a track bike
MichaelK
michaelkei is offline   Reply With Quote
Old Feb 1st, 2012, 3:59 pm   #10 (permalink)
Should test their underbelly design once they release it for the SF too... I wanna know the differences before I buy...
bgbsi06 is offline   Reply With Quote
September Exhaust and Re-tune Special moto Vendor Specials and Group buys 0 Sep 2nd, 2011 2:17 pm
September Exhaust and Re-tune Special MotoRefugee Motowheels 0 Sep 1st, 2011 5:13 pm
Double Dog Exhaust 53Monster1100 StreetFighter 68 Mar 30th, 2011 2:36 pm
looks like double dog finished their exhaust blawrence StreetFighter 2 Jul 21st, 2010 6:52 pm
'splain to me how to tune this exhaust hbliam HyperMotard 10 Mar 10th, 2009 9:50 pm
