Exhaust off. Lambdas & flap removed - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Jan 30th, 2012, 10:00 am   #1 (permalink)
blackie's Avatar
As usual Ducati make it a right pain in the arse to remove anything.
Exhaust removed.
1. Remove right rearset and carbon shields.
2. Remove both bottom body panels
3. Remove right undertank side panel
4. Disconnect servo cable ( if connected)
5. Remove cans
6. Remove all springs
7. Undo bolt to rear cylinder pipe . Above rear master cylinder.
8. The rear section should now pull off
9. Trace lambda cable up to under seat and disconnect.
10. Undo both sides of bottom radiator.
11. Undo bottom rad bracket from under horizontal cylinder.
12. Undo oil cooler from bottom left side and pull slightly away.
http://www.ducatiworld.co.uk
blackie is offline   Reply With Quote
Old Jan 30th, 2012, 10:01 am   #2 (permalink)
blackie's Avatar
13. You can then access the nuts for the front pipe.
14. Cable from front lambda is connect under the tank above the airbox.
15. Undo nuts to rear cylinder pipe
16. That should be it all off
The exhaust removed. The lambda sensors removed & the exhaust flap ground & smacked out ready for the holes to be welded up.
Then its off to camcoat for a nice coat of satin black
Fantastic
Old Jan 30th, 2012, 10:35 am   #3 (permalink)
Expand the mind. Not a fuel tank
Wonway's Avatar
Now that's a proper mod. Grinding and beating that exhaust flap works well!
You could always go polished too
Wonway is online now   Reply With Quote
Old Jan 30th, 2012, 10:40 am   #4 (permalink)
blackie's Avatar
Ahhh.........My eyes..
No, the stealthy look for me. Cant be having shiny on it.
Gollum will be after it.
Old Jan 30th, 2012, 10:43 am   #5 (permalink)
blackie's Avatar
A nice man at work has welded the holes up for a sum of 10 English pounds..
So its off to the coaters this week
Should be back in a fortneet
Old Jan 30th, 2012, 10:49 am   #6 (permalink)
Sick!!!
King Cold is offline   Reply With Quote
Removing the exhaust valve flap Wonway StreetFighter 77 Mar 1st, 2011 9:50 pm
Installed double dog exhaust and removed footpegs gragravar StreetFighter 11 Jul 20th, 2010 1:40 am
ST Mud Flap jackoduc Sport Touring 2 Jul 13th, 2008 6:18 pm
Wing Flap?? zsnnf Superbikes 14 May 30th, 2007 7:18 am
