Why is my new Shorai battery only at 12.2V?? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 9th, 2012, 4:58 pm   #1 (permalink)
Question regarding the Shorai battery. I just installed a brand new Shorai LFX14A2-BS12 battery in my SF. Went out for couple of hours. The voltage on the dash was good, between 13.9-14.0V Shut off the bike, parked it overnight. And today, when I check the voltage on the dash, it reads 12.2V.. And Shorai instructions say" Do not allow discharge below 13.0V". So im like wtf?? I dont have any draining accessories on the bike, only thing is the stock red blinking light when the bike is shut-off. I still don't know what the light does.
2010 Streetfighter S
komodo is offline   Reply With Quote
Old Jan 9th, 2012, 5:04 pm   #2 (permalink)
Gm sf's Avatar
Don't worry bout that my dash nearly always reads low bat,voltage reading will drop when ignition is on,if your concerned take reading at the terminals with the ignition off,I did have a battery issue in the first month of ownership,but I could hear it getting really lazy to start so I got them to replace it under warranty.
Gm sf is offline   Reply With Quote
Old Jan 9th, 2012, 5:07 pm   #3 (permalink)
zvez's Avatar
doesn't the voltage drop off in very cold weather and think picks up when warmed?
Chris
12 1199 Panigale......May 26th?????????????????????
10 Ducati Streetfighter
2011 Aprilia RSV4-R APRC
05 Goldwing
zvez is offline   Reply With Quote
Old Jan 9th, 2012, 6:47 pm   #4 (permalink)
oalvarez's Avatar
I believe that to be the case, and why Shorai themselves suggest "warming" the battery (lamps on, heated grips on, etc) prior to starting in the colder temps.
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is online now   Reply With Quote
Old Apr 17th, 2012, 5:37 pm   #5 (permalink)
2fasst's Avatar
komodo, any updates. Your problems sounds SO similar to mine. except mine came off the BMS01 charger a few hours earlier.
2005 R1-Marchesini, Graves Full System, Custom map, Ohlins R&T, Ohlins Shock, STM Slipper, PVM 20x18, BrakeTech iron rotors, Sato rear sets.
2006 999R Xerox-Leo Vince Full System, Custom map, Brembo Masters, Sato rear sets
2007 GSXR750 Track-Ohlins 25mm cartrigdes. TTX shock, Yoshi TRC Slipon, Custom map, Woodcraft engine covers, Sato rear sets, Brembo master
2fasst is online now   Reply With Quote
Old Apr 17th, 2012, 6:51 pm   #6 (permalink)
Secret Squirrel's Avatar
I don't think you have anything to worry about. Any battery is going to have a voltage drop after you take it off the charger or when you come home from a ride and turn the bike off. It's called resting voltage. As long as the resting voltage is not lower than 12V the battery is usually fine. The problems start when you put a load on the battery and the voltage drops down lower than acceptable and the bike either won't crank or cranks really slow. This is usually an indicator of a cell going bad in a lead acid battery. If you've never watched voltage numbers either with a hand held volt meter or on an instrument cluster these changes can be alarming to some people. People need to have a good understanding of the fluctuations and what is normal and how the bike sounds when it starts normally. I hope this helps.
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is offline   Reply With Quote
Old Apr 17th, 2012, 7:18 pm   #7 (permalink)
DuckMan's Avatar
That doesn't sound right. The Shorai in my Monster has been sitting for two week since last ridden and reads 13.35 volts. It has never been on a charger.
Mike
DuckMan is online now   Reply With Quote
Old Apr 17th, 2012, 7:21 pm   #8 (permalink)
2fasst's Avatar
Does your monster have a flashing light on the dash? I know mine has a problem, because I was stranded.
Old Apr 17th, 2012, 7:24 pm   #9 (permalink)
DuckMan's Avatar
Yes but it stops after a couple of days.
Mike
Old Apr 17th, 2012, 7:32 pm   #10 (permalink)
Maybe I'm wrong with some of the information I posted above. It's possible he has a weak cell. Since Shorai states not to let the battery discharge below 13v. That could imply that they have a higher resting voltage then a lead acid battery. I'm not a Shorai expert. Does this mean that the Shorai batteries have a higher resting voltage? 13volts or more?
Hyper Shorai Battery Install ajpags HyperMotard 36 Apr 15th, 2012 10:27 am
Shorai battery install on my '97 916 chairmanpato Ducati Motorcycle Chat 8 Sep 8th, 2011 6:00 pm
Shorai Lithium Battery ?? tunaman Superbikes 20 Mar 19th, 2011 9:10 am
Which Shorai Battery? 999_FZ1 Superbikes 6 Feb 21st, 2011 1:41 pm
anyone tried a shorai battery yet? paulmm600 Superbikes 15 Jan 24th, 2011 9:16 am
