Originally Posted by Aussie Biker
Can someone please provide some guidance for the replacement of the water pump cover. I have bought a Speedymoto cover to replace the scratched original.
I would imagine that the coolant will need to be drained and refilled once the cover is replaced. I'm not sure about the bleeding process.
Thank you in advance.
Ive never actually replaced the cover itself, but fitted a couple of different protectors. While fitting these fluid has leaked out which suggests that you would need bleed the system There is a little screw/plug at the bottom of the lower radiator that is used to bleed the system. Ive read on here that its quite easy to do, just making sure you dont get any trapped air in the pipes once refilled.
