Air in clutch master. - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Old Jan 3rd, 2012, 6:32 pm   #1 (permalink)
So i noticed the other day that all of a sudden the clutch was not doing anything until halfway through lever travel. Also it felt kinda spongy for the first half. I assumed it needed to be bled and took the reservoir cover off to start the process. First thing i noticed was the fluid looked low. Not low enough to let air in the system but still a little low. So i looked for and found no obvious leaks. I bled the system at the slave with no change. So i bled the system at the master and it immediately fixed the problem. How did that air get in there? lol. Figured i would post in case it happens to anyone else.
usefulidiot is offline   Reply With Quote
Old Jan 3rd, 2012, 6:40 pm   #2 (permalink)
LaRossa's Avatar
Images: 13
You may have a bad seal in the slave, it happened to me with the Oberon and while you're mentioning the fluid being low, I have the feeling it's the same. Check around the slave cilynder perimeter, around the bolts, if you see wetness get it off, the fluid will eat the powder coating.
I didn't figure it out right away and that's what happened, if not, bleed the clutch on the top, with the 11mm at the lever, bubbles rise so that's the best place to purge it IMHO.
2012 MTS 1200 PP#142
2010 SFS
2010 1198S Corse (Sold)
2006 999R (Sold)
2007 1098S Tricolore (Sold)
2004 MV Agusta Brutale 750 America "Moto Corse" (Sold)
2006 S4Rs (Sold)
LaRossa is offline   Reply With Quote
Old Jan 3rd, 2012, 6:46 pm   #3 (permalink)
I did bleed at the top and it's working normally now. I didnt take the slave off but there was no trace of a leak from what i could see without unbolting. If it happens again i'll take it off and look behind it.
Old Jan 3rd, 2012, 6:52 pm   #4 (permalink)
LaRossa's Avatar
Images: 13
Mine was the same, built air within a 20 min ride, after bleeding it 3 or 4 times and changing the brass washers I realised the problem was down below.
Just keep it in the back of your head.
2010 SFS
2006 999R (Sold)
2006 S4Rs (Sold)
Old Jan 3rd, 2012, 10:07 pm   #5 (permalink)
flynbulldog's Avatar
check the FAQ...
All Ducatis seep a little air into the master within several thousand miles. This is normal and it should be "burped" about once a year.
Anybody who hasn't read through the FAQ should do it so you know what info is available to you.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
74 Duc 750 sport special
66 Duc 250 NC racer
65 Norton Atlas cafe'
flynbulldog is offline   Reply With Quote
Clutch master parts bang76 Supersport 4 Dec 1st, 2011 3:15 pm
WTB: 999 749 clutch master cylinder SOUR_ORANGE Parts and Accessories 4 Aug 8th, 2011 11:45 pm
Will a 749 Radial Clutch Master Cylinder Lighten the 900SS Clutch Weight? robnobrakes Ducati Motorcycle Chat 4 Aug 11th, 2009 4:34 pm
clutch master RockingM Sport Touring 1 Oct 11th, 2008 2:06 pm
Air in clutch master? JohnBoy Sport Touring 13 Dec 22nd, 2006 6:43 pm
