Alternator plug from the Voltage regulator - Ducati.ms - The Ultimate Ducati Forum
Old Jan 3rd, 2012, 4:01 pm   #1 (permalink)
samw5's Avatar
So I'm having a bit of trouble locating the plug onto which the alternator plug is getting plugged into (seen plug B in the picture below).
I'm in the process of putting the bike together and everything is going well but is particular plug is left without a connector for it.
I could not find the receiving end on the main harness anywhere... Am I missing something? The cable comes from the voltage regulator as well. The other cable was correctly plugged into the main harness.
Everything else was plugged in...let alone the second lambda and exval connectors since they are now gone (ECU was remapped).
Also I'm assuming the other plugged connector near the ECU is where the computer gets connected to to reset the TPS.
2010 SF tricolore.
samw5 is offline   Reply With Quote
Old Jan 3rd, 2012, 4:34 pm   #2 (permalink)
It appears that you have the manual. Go to the end of the electrical section and you'll find color illustrations of all the connectors when they're plugged in.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is online now   Reply With Quote
Old Jan 3rd, 2012, 5:17 pm   #3 (permalink)
samw5's Avatar
I have, trust me...
Still couldn't see it
2010 SF tricolore.
Old Jan 3rd, 2012, 5:52 pm   #4 (permalink)
FlyingQ's Avatar
Yes, the connector for the diagnostics is on the right hand side with a cap on it. It is #18 on Plate G.
Working on finding the Regulator/alternator connector on my bike, so stand by and I let you know what I can find.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Jan 3rd, 2012, 5:54 pm   #5 (permalink)
samw5's Avatar
Thanks bud... Connector is on plate F but I can't see where it's plugged into.
2010 SF tricolore.
Old Jan 3rd, 2012, 6:52 pm   #6 (permalink)
FlyingQ's Avatar
OK, so looking at the wiring diagram, wire color code chart, wiring plates, and my bike here's what I looking at. I took as many of the panels off my bike as I could without fully removing the tail, but still couldn't clearly see #16.
My bike has the two connectors running to/from the voltage regulator.
#16 is a smaller connector tucked up under the frame rail back by the regulator on the left side and has four wires running to/from it (2 red, 2 black). It is hard to get to/see with the tail section on and it is the voltage regulator connector.
#15 is a large white colored connector mounted on the left side zip tied to the frame rail almost directly below the left seat mount nut plate and has three larger gage yellow wires (they may be brown colored right at the connector, but become yellow with in a cm or so) running to/from it. #15 is the regulator/alternator connector. It is easy to get to with the seat off.
Both connectors are part of main wiring harness.
Make sure you have the EX-UP connector isolated. It is a smaller square shaped connector, also on the left side near the regulator/alternator connector. The EX-UP connector has four wires running into it: one black, one yellow, one green & red, and one brown & black. I covered mine over with electrical tape. It appears to be similar to the regulator connector (#16), so be careful to get them correctly connected. Check the wire colors with the diagram (download the pdf version of the diagram from the manual so you can see it clearly). Hope this helps.
Cheers.
2000 Monster 900S
2004 749S (gone)
Old Jan 3rd, 2012, 7:05 pm   #7 (permalink)
FlyingQ's Avatar
I'm pointing at the regulator/alternator connecter (#15).
I'm holding the EX-UP connector (#21) that I taped over since the EX-UP is long gone. The diagonostics plug (#18) is directly to the left of my index finger next to the frame tube. It has the black plug cover on it.
2000 Monster 900S
2004 749S (gone)
Old Jan 3rd, 2012, 7:29 pm   #8 (permalink)
samw5's Avatar
I'm holding the EX-UP connector (#21) that I taped over since the EX-UP is long gone. The diagonostics plug (#18) is directly to the left of my index finger. It has the black plug cover on it.
Thanks FlyingQ!! Ya definitely 15 that's the issue. Already taped the valve and o2 sensor but somehow missing the alternator plug from the main harness... Gonna have to go fishing for that one somewhere... Just hope it isn't too far up as I've already put the air box back on.
2010 SF tricolore.
Old Jan 3rd, 2012, 9:22 pm   #9 (permalink)
samw5's Avatar
Found it... Somehow I routed the cable from the main harness to the front.... Not sure how it ended up there but it's apparently not bundled with the rest of the harness that goes in the subframe so I must have missed it.
Pictures where an awesome help as I knew what to look for.
Finished trimming the rear carbon fiber fender to clear the CRM exhasut... Handlebar is back on... Next is the controls and trying to get the plastics to paint (and decide which color to go for)....
Cheers,
Sam
2010 SF tricolore.
Old Jan 3rd, 2012, 9:44 pm   #10 (permalink)
FlyingQ's Avatar
Fantastic! Sounds like it's coming back to life...well done.
2000 Monster 900S
2004 749S (gone)
Regulator/Alternator problem JohanM Vintage 2 Jun 21st, 2009 12:52 pm
alternator voltage is? dkeyser48 Supersport 5 May 28th, 2009 6:32 pm
Regulator/Rectifier/Alternator went on my 848 hawc Superbikes 18 Oct 28th, 2008 11:55 am
888 alternator resistance / voltage ? johnboy888 Superbikes 5 Aug 17th, 2006 10:39 am
916 voltage regulator davy916 Superbikes 4 Jun 12th, 2006 12:01 am
