Very quick problem Clutch! - Ducati.ms - The Ultimate Ducati Forum
Old Jan 3rd, 2012, 2:55 am   #1 (permalink)
Horseonly's Avatar
Hi all,
I am currently half way through fitting a new EVR Clutch, I opted to replace the Clutch drum with a NGR Billet unit. I am pretty sure but wanted to check either way that the inc. Cup Washer sits between the lock nut and the drum NOT between the drum and basket.
Has anyone fitted one of these? (I realise this is probably a stupid question to you boys that pull your bike to bits and re-build it again and again but I'm a beginner at do this stuff)
Cheers
~ Ducati Streetfighter S (will never sell!!)
~ Triumph Speed Triple 1050 (Sold)
~ Buell XB12S (Sold)
Horseonly is offline   Reply With Quote
Old Jan 3rd, 2012, 4:35 am   #2 (permalink)
Horseonly's Avatar
Hi all (again),
I followed what I thought was best and placed the lock washer between the nut and the drum, finished putting it all together.
Then gave her a run,
My only issue now is that the clutch doesn't seem to be engaging completely. It is grabbing but not enough to propel it forward.
Any ideas?
Old Jan 3rd, 2012, 8:17 am   #3 (permalink)
WNM
I can't speak to the basket but ran into similar problems with the EVR unit. The initial install was with an Oberon slave... No luck so I switched back to the stock slave. Still didn't work right. So I ordered an EVR slave and all worked great. I can't remember for sure but I believe that the stock and Oberon unit wouldn't push the rod far enough to release the friction from the clutch plates. I played with the stack height to but couldn't get it to work. Basically the length of the stroke on the slave needs to be such that it allows the stock rod enough movement to both release the tension on the clutch plates due to the springs and enough travel to allow the springs to compress the stack of clutch and friction plates.
Hope that made sense.
WNM is offline   Reply With Quote
quick clutch bleeding question crashdown Superbikes 6 Apr 29th, 2011 5:08 pm
Problem with metal quick disconnects. Maryland998 Superbikes 8 Mar 7th, 2011 9:43 pm
Quick Clutch question. mry999eryk Superbikes 0 Mar 30th, 2010 12:58 pm
Quick clutch question.. aviatortroy Supersport 2 Oct 16th, 2009 12:02 pm
Quick Clutch Questions 2000 996S Superbikes 1 Aug 3rd, 2009 8:44 am
