Fitting DP Clutch Pressure Plate Question - Ducati.ms - The Ultimate Ducati Forum
Old Dec 24th, 2011, 12:09 pm   #1 (permalink)
Question Fitting DP Clutch Pressure Plate Question
I have just bought a nice DP ventilated clutch pressure plate and the instructions give fitting instructions for SBK, Monster and Hypermotard but not the SF. The options are effectively to use no washers (SBK), one washer (Monster) or two washers (Hyper) for each spring. Any guidance please?
1997 Ducati 750SS
2011 Ducati Streetfighter
www.pbase.com/yellowduke
Yellowduke is offline   Reply With Quote
Old Dec 24th, 2011, 1:18 pm   #2 (permalink)
Depending on which washers you are talking about I installed one washer behind the clutch hub on top of the funny shaped spacer. Each slipper is different but I used the following website for instructions for my Bucci DP slipper.
Clutch Tuning - Ducati Up North
2005 Ducati 748 - sold
2002 GT aggressor mountain bike
2001 Honda CBR600F - sold
1999 Suzuki SV650S - sold
Mrsmith is offline   Reply With Quote
Old Dec 24th, 2011, 3:20 pm   #3 (permalink)
It's just a plate no slipper clutch. The washers are described as "spring loading washers" and later as "shims under pressure plate". There are 5 configurations. For SBK, no washers/shims or a single washer/shim on 3 of the 6 springs. For Monster, one washer/shim for each spring or 3 with one and 3 with 2. For Hyper, 2 washers/shims on each spring.
The instructions indicate that using all the washers will decrease effort at the lever. I'm inclined to think that is just bad translation and really means less lever travel but I'm not sure. Any ideas?
1997 Ducati 750SS
Old Dec 24th, 2011, 4:21 pm   #4 (permalink)
Excuse my mistake, no washers req
Old Dec 24th, 2011, 5:29 pm   #5 (permalink)
The washers decrease spring tension, which decreases lever effort. I leave them out. I reduced lever effort with an aftermarket slave cylinder.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is online now   Reply With Quote
Old Dec 24th, 2011, 8:08 pm   #6 (permalink)
I also have the do plate. No washers used. But make sure the plate is lined up with the marks on the housing.
meme is offline   Reply With Quote
Old Dec 25th, 2011, 7:21 am   #7 (permalink)
I think I might pop 3 in and see how it goes. I have some stainless springs on order anyway and they might make a difference.
1997 Ducati 750SS
Old Dec 25th, 2011, 9:37 am   #8 (permalink)
FlyingQ's Avatar
I had some SpeedyMoto SS springs on one of my clutches a couple of years back. They look good and did't rust, but they "compressed" over time faster than the OEM springs. They were well out of limits after about 8k miles. So, just be aware to check them when you do the 6/7.5K services.
I've never used any washers on the springs.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Feb 26th, 2012, 10:26 am   #9 (permalink)
I held off fitting the pressure plate until I had an Oberon slave cylinder as well. I suffered a bad case of arm pump on a trip to a rally at the end of January. Stop start traffic due to an accident and it was all uphill. I nearly had to pull over it got that bad. Should have held off on fitting the shorty Pazzo levers!
Fitted everything today and am pleased with the results. Nice pull on the clutch but the proof will be in a ride in traffic.
[IMG][/IMG]
[IMG][/IMG]
1997 Ducati 750SS
Old Feb 26th, 2012, 12:06 pm   #10 (permalink)
What size slave did you go with? I see 28, 30, etc... Not sure which to buy
1198 clutch pressure plate and pushrod question avaipan2 Superbikes 14 Dec 10th, 2011 2:26 am
Slipper Clutch Question - Pressure Plate bthomas9 Ducati Motorcycle Chat 3 Oct 15th, 2010 5:50 am
Help needed fitting clutch presuure plate brightonduke Sport Classic 8 Jun 3rd, 2007 12:48 pm
STM Clutch Pressure Plate Owners - Question RickTv60 Ducati Motorcycle Chat 2 Oct 7th, 2006 11:14 am
Yet another clutch cover/pressure plate question slowerthan Ducati Motorcycle Chat 10 Sep 18th, 2006 9:16 am
