Info on fueling please! - Ducati.ms - The Ultimate Ducati Forum
Old Dec 13th, 2011, 7:36 am   #1 (permalink)
Gm sf's Avatar
About to buy a full system for my SF and was wondering which is the best option....tuneboy or a powercommander or any other suggestion would be grateful thanks
Oh and what's a "dp ecu"? Seen this written a few times now
This is all probably basis stuff to you guys sorry but I'm used to jap stuff,simple pipe and power commander and a decent map usually does cheers!
Gm sf is offline   Reply With Quote
Old Dec 13th, 2011, 8:56 am   #2 (permalink)
FlyingQ's Avatar
Wow, where to start??? There are many, many threads here on various solutions to the fueling issue. Some work well, some not so well. I'd say get a really big cup of coffee, read up in the FAQs section here, then refill the cup and do a search in the SF forum under "fueling", "tuneboy", "ECU", "powercommander", etc.
I'm using a Redline reflashed ECU. Works well, relatively inexpensensive, but does require someone who has the proper experience to set the TPS, balance, fuel trim, and bleeds (ie,... a normal tune) to get the most out of it. Best of luck.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Dec 13th, 2011, 10:50 am   #3 (permalink)
flynbulldog's Avatar
Unfortunately GM this is not basic stuff with Ducati. It is a major problem with Ducati and it can be quite complicated and frustrating.
As FlyingQ says read the FAQ at the top of the streetfighter section and do a few searches - much has been written
DP stands for "Ducati Performance". DP is Ducati's aftermarket accessory line.
ECU is the 'electronic control unit" or the bike's computer.
We all wish it was black and white and there was a best option. That's just not the case.
Good luck.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
74 Duc 750 sport special
66 Duc 250 NC racer
65 Norton Atlas cafe'
flynbulldog is online now   Reply With Quote
Old Dec 13th, 2011, 11:58 am   #4 (permalink)
Gm sf's Avatar
Thanks for the advice lads I'll have look with a large coffee in hand lol
Old Dec 13th, 2011, 6:37 pm   #5 (permalink)
You'll need more than coffee my friend!
61 175 TS
73 750 Sport
74 750 Sport
74 750 GT
75 750 GT
75 750 SS
02 Foggy Monster
07 SC1000SportClassic with a sealed gas tank and some mods.
93 Superlight
04 Moto Guzzi V11 Sport
Streetfighter S with some mods and a sealed gas tank.
Scheming for a 1199TriColore
"Perfection is a worthwhile goal if you don't expect to achieve it"
TheDucnutOfBevelville is offline   Reply With Quote
Old Dec 14th, 2011, 1:07 am   #6 (permalink)
liebig's Avatar
GM.
Most important is to get out of the fekkin loop that the standard ECU (in standard shape) puts you back in between 0 and 5000 (i think it was) rpm.
That fekkin loop makes PC's, Bazzazes or what-have-ya useless between those revs - which is where you'll find the "problem".
Getting your ECU reflashed will help. Or getting a Ducati Performance ECU. And maybe there are other up-graded ECU's you can find?
I go with a DP ECU and a nicely dialled in PC V meself. I'm well happy.
The advantage with PC V, Bazzaz e t c is you can finetune (experiment with) the settings as you go along (which I have also done).
Whatever makes you and your wallet (missus?) happy.
liebig is offline   Reply With Quote
Old Dec 14th, 2011, 5:47 am   #7 (permalink)
indianfighter's Avatar
If you have access to a good tuner who can reflash your ecu do that, it's the easiest.
If not then get the tuneboy but it's a pain and lot of work to get it to do what you want. It's apparently very powerful and feature filled.
Indianfighter
Mumbai, India
2009 SF
indianfighter is offline   Reply With Quote
Different fueling problem Ducposer StreetFighter 24 Nov 24th, 2011 12:03 pm
Misc. info, upgrades, tech tips, restoration info, etc. tricklidz Hall of Wisdom 1 Mar 3rd, 2011 6:42 pm
Fueling woes... bmartinek HyperMotard 7 Aug 26th, 2010 1:31 pm
My new 696...bad fueling? desmodrone Monster 16 Jun 25th, 2008 8:27 pm
GT1000 Fueling - Need answers High_side Sport Classic 35 Mar 5th, 2008 5:36 pm
