Rizoma Star clucth plate install - Ducati.ms - The Ultimate Ducati Forum
Old Dec 12th, 2011, 5:13 pm   #1 (permalink)
Hi guys,
The missus is buying me a rizoma star clutch plate for xmas and just wanted to see if their is anything tricky about the install or anything I should watch out for. I have seen the post by one of the users which outlines the process (very good post) but thought I would check anyway.
Thanks
philjt is offline   Reply With Quote
Old Dec 12th, 2011, 5:59 pm   #2 (permalink)
Tripod's Avatar
Pretty straight forward. If you read up on it, then you know to line up the marks.
Sent from my iPhone using Motorcycle
Mark - 2001 Monster S4 Senna
Being led astray by Wonway for 2 years.
Tripod is offline   Reply With Quote
Old Dec 12th, 2011, 6:05 pm   #3 (permalink)
riva996's Avatar
+1 line up the marks. Easy Peasy job. I think the torque on the springs was 12lbs?
'12 Pikes Peak #195
'99 - 996
'03 RoadKing-sold
'00 Fatboy-sold
'57 Knuckle- sold
'89 Suzuki R400r-sold
riva996 is offline   Reply With Quote
Old Dec 12th, 2011, 6:11 pm   #4 (permalink)
thanks very much, I did read up on the install and did take note of the marks as some people seemed to miss that step. I have a torque wrench small enough for the settings so that shouldnt be a problem.
Thanks
Phil
Old Dec 12th, 2011, 6:46 pm   #5 (permalink)
FlyingQ's Avatar
I am not familiar with the Rizoma pressure plate or it's installation, but...
If you are talking about the 6 bolts that go through the springs and hold the pressure plate on, be very careful. If you use 12 ft/lbs, you'll probably snap them off. From the Service Manual torque specs:
Dry clutch spring bolt
M5x0.8
Min Torque 5 Nm (3.68 ft/lbs)
Max Torque 7 Nm (5.17 ft/lbs)
Recommended Torque 5Nm (3.68 ft/lbs)
Just snug them up with a t-handle wrench...not tight. The springs keep them under tension and will help hold them in place. They are prone to seizing/breaking if they were previously tighten way down and have been in there for a while. I also use a very light coat of grease on the threads when re-installing them. Merry Christmas.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Dec 12th, 2011, 7:18 pm   #6 (permalink)
Thanks for the info, yeah I did think that 12lbs was a pretty excessive, from the service manual I have and from what I have read in previous posts 5nm was what I was going to apply.
Cheers for pointing that out.
Old Dec 12th, 2011, 11:57 pm   #7 (permalink)
Maximmagnum's Avatar
12lbs is not sufficient information... torque requires a length unit. 12 pound inches is not enough, and 12 pound feet is way too much. So total fail (not trying to be harsh, but if somebody listened to your advice, they could do damage to their bike, so please check your numbers before posting something like that...although, people should know when they realize 12lbs is not a torque...)
James
-White F1098 Streetfighter
Maximmagnum is offline   Reply With Quote
FS: CHEAP Rizoma Clutch Cover & Star Pressure Plate chief rocka Parts and Accessories 1 Nov 30th, 2011 7:14 pm
Rizoma Star-Style pressure plate question sturmgewehr Superbikes 2 Sep 29th, 2011 3:48 pm
Install of Rizoma Rearsets Tomster the Duc HyperMotard 9 Feb 2nd, 2010 1:10 pm
Help Dry Clucth Is Wet! Ducatibomber Sport Classic 0 May 17th, 2009 9:10 pm
Help with Rizoma blinker install?? triblk6spd HyperMotard 3 Aug 12th, 2008 11:23 am
