Dead Battery - Ducati.ms - The Ultimate Ducati Forum
Old Dec 11th, 2011, 9:47 pm   #1 (permalink)
Dead Battery
Pardon me for posting a noob question, and not using the search option.
this morning as i was about to take my bike to work, the bike wouldnt start, the battery was almost dead, tries to use the ignition switch a couple of times.. and it was completely dead.
the weather here is not cold at all these days, mid 30s in the morning and around 15 degree celcius at night. i havent started the bike in 2 weeks at all.
the bike is pretty new ( 2011 ) and hence the battery as well, is this normal?
how do i prevent this from happennig?
and easiest way to recharge the bettery ?
plz plz do tell me know what is the best way to jump start
wouldnt be able to thank u guys enough
kachhhing is offline   Reply With Quote
Old Dec 11th, 2011, 10:26 pm   #2 (permalink)
Sputniks's Avatar
I would take it as an excuse to get a lightweight cell battery.
Sputniks is offline   Reply With Quote
Old Dec 11th, 2011, 10:53 pm   #3 (permalink)
(1) Don't run the battery completely dead or it will sulphate and therefore become junk.
(2) Just put it on a trickle charger (battery tender) overnight and you'll be good to go in the morning.
(3) If you're gonna jump it, be careful to hook up the leads in the correct order or you'll get sparks.
Cheers,
j
R.I.P. #58
2008 848 Red/white/black - track puppy (Francesca)
2008 S4Rs Tricolore #293 (Isabella)
2011 MTS S Touring - Black (Sofia)
oleary is offline   Reply With Quote
Old Dec 12th, 2011, 2:40 am   #4 (permalink)
oleary is right..you should buy a trickle charger (battery tender) and hook it up with your bike when specially when you are not using it for a long period of time...that's also a subtle way of your bike telling you to ride it more often...
darrenSF1098 is offline   Reply With Quote
Old Dec 12th, 2011, 3:25 am   #5 (permalink)
indianfighter's Avatar
see if you can push start it in 2nd gear?
It's not normal for the battery to die so soon.
Indianfighter
Mumbai, India
2009 SF
indianfighter is offline   Reply With Quote
Old Dec 12th, 2011, 7:03 pm   #6 (permalink)
samw5's Avatar
Also remember that hotter temps are worse for discharge rates. Batteries will drain out sooner when warmer out than when it's freezing.
That said had the same issue with mine. Dealer tested it and said it was ok but I still don't trust it, to the point I keep it on a tender at all times now.
2010 SF tricolore.
samw5 is offline   Reply With Quote
Old Dec 13th, 2011, 4:21 am   #7 (permalink)
Battery tender always when the bike is parked.
TallyRex is offline   Reply With Quote
Old Dec 18th, 2011, 2:20 pm   #8 (permalink)
up and about
update on the battery,
tried to jump start in 2nd gear, it wouldnt start.
took the battery in , and the guys at ducati said it was completly dead, and i could physically see sulfur.
got a new battery, similar that the bike came with.
also got a battery tender, called optimiser 3 , didnt get time to do research on this, so took the dealer`s word for granted.
i have left the tender on the bike ever since i got the new battery , [B]is that alright?
i couldnt figure out how to install in such a way that it is easily accessible yet stays concealed.
here is a pic of what i managed to do.
Old Dec 18th, 2011, 3:17 pm   #9 (permalink)
Correction , its called optimate 3+
Old Dec 18th, 2011, 3:41 pm   #10 (permalink)
Excellent choice kachhhing.
All the new bikes that are sold from my local dealership have an optimate lead fitted when PDI is done so as to give the customer the incentive to keep the battery in tip top condition.
mr shifter is offline   Reply With Quote
Battery's so dead, Battery Tender will not charge it... Tag Sport Classic 11 May 29th, 2011 3:31 pm
HID's on a xx9/Dead battery? jds3 Superbikes 9 Jan 20th, 2011 12:46 pm
Dead battery remery HyperMotard 1 Feb 16th, 2010 5:09 pm
Dead Battery 2004 ST4s "is it a special or regular off of the shelf battery?" 2UpDuc Sport Touring 26 May 10th, 2008 2:10 pm
Will my battery be dead? brianmdavis Superbikes 5 Apr 12th, 2006 12:27 am
