Clutch judder - Ducati.ms - The Ultimate Ducati Forum
Old Dec 7th, 2011, 3:32 pm   #1 (permalink)
Gm sf's Avatar
Clutch judder
When pulling away I can hear/feel a judder from what I think is the clutch,is this a common prob with the
Streetfighter? Came into it not long after I burnt the end of a tyre of it cheers!
Gm sf is offline   Reply With Quote
Old Dec 7th, 2011, 3:43 pm   #2 (permalink)
Are you used to I4's? twins tend to be grouchy and juddery at low revs, it's those two big pistons causing it. Different fueling maps can also help. Try slipping the clutch a little more at lower revs, it's what I do.
thought is offline   Reply With Quote
Old Dec 7th, 2011, 3:48 pm   #3 (permalink)
Gm sf's Avatar
It's not the engine configuration I'm pretty sure it's the clutch assembly,a very harsh judder bit like a wet wet brake drums on a car and I can feel the vibe through the bike,once the clutch lever is out and I'm moving it's gone,it's under the torque and initial bite
Old Dec 7th, 2011, 3:53 pm   #4 (permalink)
Mine did that when it was new and it eventually went away. At the 7500 mile service the dealer did a thorough disassembly and cleaning of the clutch pack and the noise/feeling came back. As before it eventually stopped. For me it just appears to be a case of the clutch pack being a little grabby when it's in a freshly cleaned state.
keith-sfs is offline   Reply With Quote
Old Dec 7th, 2011, 4:02 pm   #5 (permalink)
Gm sf's Avatar
There's 12,750 kms on the bike,I've owned it since new,thanks for the advice I'll strip it out and a have look and see what's what
Old Dec 7th, 2011, 10:18 pm   #6 (permalink)
Expand the mind. Not a fuel tank
Wonway's Avatar
You've owned it sine new with that many miles on it and now you are asking if it is normal?
Well, is it?
Wonway is offline   Reply With Quote
Old Dec 7th, 2011, 10:57 pm   #7 (permalink)
Official Sponsor
desmoworks's Avatar
It is common to Ducati dry clutches. This is why EVR created the progressive engagement pressure plate.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old Dec 8th, 2011, 3:47 pm   #8 (permalink)
Gm sf's Avatar
Thanks for that link desmoworks that sounds exactly what my bike has developed this past couple of thousand km's
Old Jan 8th, 2012, 5:31 pm   #9 (permalink)
Gm sf's Avatar
Update on clutch judder feeling.
I stripped put the clutch today to find it quite dirty and the clutch basket and clutch friction plate tabs to be worn (where they contact each other)
I'm sure this is whats causing my problem and I can see how the E.V.R progressive pressure plate can dampen this out,I'm not sure if I should file/smooth the burrs off the basket and plates or would this increase the tolerance too much??? ,advice would be grateful,I'm going to order a workshop manual on cd rom to aid in my future efforts.
Old Jan 10th, 2012, 8:20 am   #10 (permalink)
mojodog's Avatar
I had to file/de-burr mine. Its not ideal but it will buy you some time. You can scuff and flip your metal plates(not the concave one)also.
mojodog is offline   Reply With Quote
Running steel clutch pack in an hard anodized clutch basket... ZDM Superbikes 9 Jul 6th, 2010 4:36 pm
Will a 749 Radial Clutch Master Cylinder Lighten the 900SS Clutch Weight? robnobrakes Ducati Motorcycle Chat 4 Aug 11th, 2009 4:34 pm
Installed Pazzo Clutch Lever...now the clutch doesn't disengage 100% koolio Superbikes 11 Aug 18th, 2007 4:31 pm
Picked up my '01 996S! Newb to Slipper and Dry Clutch...pulsating clutch handle? Dana Superbikes 13 Jun 7th, 2007 6:37 pm
Front end judder??????? trev916 Superbikes 7 Apr 3rd, 2006 1:46 am
