Installation. Instructions/tips for Tapered steering bearings
So I got a set of tapered steering bearings for the bike since I broke one of the stock roller bearing while pulling the fork out (cage snapped).
Question is regarding the install since they did not come with instructions.
Looking and trying them on the steering column I'm assuming I'll need to remove the race inside the frame steering column and that near the lower tree.
I think this can be done with punches and a pry bar.
Once removed use a socket or piece of PVC pipe to pressure but the bearing and race in place.
While the lower race look like it can be flushed with the lower triple I'm not sure about spacing on the top race and how to measure it.
Any thoughts? I'd hate to have to buy a new stock bearing set because I don't know how to install these.
Any input would be appreciated.
2010 SF tricolore.
