This would be passed on advice that Mark at the DucShop mentioned when speaking of autotune and the MicroTec.... Do not let autotune adjust the cells that are at the top of the map (lowest TPS position across the board). These cells should be left alone.
If autotune messed with these, you may want to reload your basemap, and start over, or at least copy those cells back into the map. The idle settings were on another "page", if I recall... it's been a while.
All else fails, take it to a competent tuner for a good basemap, then use that to massage with autotune. That is what I did with Mark and it saves a ton of work having someone dyno it proper so that anything you tweak should only be minor.
