Tech guys please help. Fuel drip problem - Ducati.ms - The Ultimate Ducati Forum
Old Nov 9th, 2011, 9:54 am   #1 (permalink)
nele22's Avatar
All,
I filled up my bike last Thursday just a few miles from my home. Rode there and parked the bike on the side stand. Left out of town until Sunday night. When I woke up Monday morning and entered the garage I was hit with a overwhelming gas smell.
Upon looking at the bike I noticed a small amount of gas under the clutch basket directly coming from the overflow hose. I removed some gas out of the tank and moved the bike. It was still dripping. Decided that I was having a tank issue and called the dealer (100 miles away.)
This morning the drip has stopped completely. Is it possible that I overfilled the bike and just removing gas from the tank was not enough? Maybe some still left in the overflow tank and hose?
nele22 is offline   Reply With Quote
Old Nov 9th, 2011, 10:19 am   #2 (permalink)
Expand the mind. Not a fuel tank
Wonway's Avatar
If you filled up the bike while upright, then went to park it on the sidestand, then it can be from the overflow. It can also be a cracked tank. We have seen both. Do you still have your evap canister? I would check to make sure it is not full of fuel too.
Wonway is offline   Reply With Quote
Old Nov 9th, 2011, 11:17 am   #3 (permalink)
That particular drain hose is the one that's supposed to drain any overflow from spilled fuel or rainwater that accumulates in the cap recess. The other hose is the tank vent, and connects to the evap canister on the left side of the engine.
If you're seeing fuel come out, you may have spilled fuel into the recess. What I'd do is to remove the gas cap by taking out the 4 allen screws visible when the cap is open. Once you remove the cap, you'll see a hole in the tank on the right side. This connects directly to the drain hose. Wipe out any fuel you may have found and then blow out the hose to remove any fuel in it. If it continues dripping after that, you have a problem inside the tank, most likely with the internal hose that connects the drain hole to the outlet fitting at the right rear underside of the tank.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Nov 16th, 2011, 11:21 pm   #4 (permalink)
WhiteGorilla1098's Avatar
I'm having the same problem. I took mine to the dealer and they checked it out.
They didn't really have an answer for me on why. About 2 months later the bike leaked again. The bike still leaks from time to time, when its hot.
Any help is welcomed.
I make sure not to over fill fuel too, so I'm sure its not that.
WhiteGorilla1098 is offline   Reply With Quote
Old Dec 2nd, 2011, 3:13 pm   #5 (permalink)
nele22's Avatar
Part of the tank swelling issue. It is being replaced by the dealer.
Help Please! Reserve Tank Problem + Fuel Guage Problem josh_ducati Multistrada 1 Dec 2nd, 2011 2:47 pm
Fuel drip Champ Ducati Motorcycle Chat 1 Oct 12th, 2010 7:00 pm
Fuel Pump drip Activator HyperMotard 1 Mar 10th, 2010 2:00 pm
Stange problem - motor starved for fuel - Opening fuel cap fixed it! neilbron Superbikes 13 Dec 8th, 2007 5:52 pm
Electronics Tech Guys TakRail Apparel and Accessory Chat 2 Jan 2nd, 2007 9:15 pm
