Front wheel bearing - ceramic? - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com
Old Nov 8th, 2011, 10:37 am   #1 (permalink)
samw5's Avatar
Just wondering if anyone ever experience with ceramic wheel bearings. I know that it's been done, just not sure about the real benefits if any (besides a bigger hole in my pocket).
The standard front wheel bearings are 6005DU (NSK was the brand on mine, I'm assuming that I could pick any other manufacturer here and it wouldn't matter... NSK bearing are made in China BTW).
Size is 47mm OD, 25mm ID, 12mm width.
2010 SF tricolore.
samw5 is offline   Reply With Quote
Old Nov 8th, 2011, 11:12 am   #2 (permalink)
TheFrog's Avatar
Images: 17
Being in the aerospace industry, I've built a few engines and drivetrains with ceramic bearings, for race cars as well. They are stronger and lighter and have a much reduced coefficient of friction. IMO, it's not useful on road or track bikes unless you're paid to win races. But then again, I feel the sae way about carbon fibre panels.
Olivier [F1098s Fighter, Monster S2R]
TheFrog is online now   Reply With Quote
Old Nov 8th, 2011, 11:16 am   #3 (permalink)
samw5's Avatar
What about durability? Are they able to carry more load? I'm assuming since the COF is reduced they would last longer than SS kinds. But ya I suppose price doesn't really tally up...
3X more for ceramic.
2010 SF tricolore.
Old Nov 8th, 2011, 11:21 am   #4 (permalink)
TheFrog's Avatar
Images: 17
I've only used them in motors, not in wheels.
In a turbine, they last very long but don't suffer hits like they would in a wheel.
I'm just guessing but i'd say that a a good ceramic bearing should outlast a steel equivalent at about 4:1
Old Nov 8th, 2011, 12:59 pm   #5 (permalink)
Ceramic bearings will carry more load without deformation, and last longer due to the increased hardness (x5-20 longer) and lower coefficent of friction. These are the main advantages for use in a wheel bearing.
Performance wise for the street, not worth it.
point45 is online now   Reply With Quote
Old Nov 8th, 2011, 1:55 pm   #6 (permalink)
Sagaris's Avatar
NSK bearings are also manufactured in Great Britain, I have a friend who worked in the high precision department at the Newark on Trent plant, just a mile or so up the road from where I live. He has mentioned several times over the years that Ducati was buying bearings from the Newark plant.
Sagaris is offline   Reply With Quote
loose front wheel... bearing? ferson206 Sport Touring 12 Jun 28th, 2011 10:14 am
99+ SS front wheel bearing codes Punch Supersport 1 Feb 20th, 2010 9:43 pm
how to remove front wheel bearing? Desmo Soundtrack Superbikes 14 Mar 19th, 2008 10:56 am
Front wheel bearing failure at 16k? dre00 Sport Touring 16 May 29th, 2007 7:22 pm
How do I identify a bad front wheel bearing? Pors Supersport 2 Aug 18th, 2006 11:29 am
