Different fueling problem - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 1st, 2011, 10:14 pm   #1 (permalink)
This is different from the low rpm stumble. When I go to get on the gas the engine revs high but then takes a second or two to get to the wheels and then it drops to a lower rpm before speeding up. It is like the bike is lagging when I get on the throttle. Is this DTC? I have the setting set at 4. The lights are not flashing red. I know when the DTC kicks in and this seems completely different. On my Multi 1200 with DTC this does not happen. What could be causing this?
http://www.ducati-owners-group.com
BarF
I BarF
You BarF
We all BarF
Bayarearidersforum
Ducposer is offline   Reply With Quote
Old Nov 1st, 2011, 10:36 pm   #2 (permalink)
Gilly's Avatar
Images: 17
Try duplicating the scenario with DTC turned off. You can also turn on your DDA and see if anything is happening with the bike... if you turn on the lap timer and when it happens, hit the high beams to mark a lap, it is easy to locate when you download the DDA run. That will show you the status of the speed, rpm and DTC activity and locating it at the lap marker is quick.
"Oh My!" thread link... FFS!
Old Nov 2nd, 2011, 3:22 am   #3 (permalink)
MrQ
It sounds like your clutch is slipping (I am not talking about a slipper-clutch). This can be caused by too weak springs or worn down clutch plates.
2009 Streetfighter
2005 R6 (Sold)
2005 R46 (Stolen)
2000 SV650S (Sold)
MrQ is offline   Reply With Quote
Old Nov 2nd, 2011, 3:52 am   #4 (permalink)
Mr M's Avatar
I had a similar issue but it was the clutch sticking ie not engaging fully immediately after the lever was released completely. It would rev like it was in neutral and suddenly kick as the clutch engaged completely.. Not long after the clutch fluid reservoir started leaking too.. Dealer had really good look at it, lubed everything that needed lubing and replaced the fluid reservoir and it is all good since than.
And yeah I had a fluid leak on the break fluid reservoir too, hope that does not happen again..
Mr M is online now   Reply With Quote
Old Nov 2nd, 2011, 7:29 am   #5 (permalink)
dharma's Avatar
Ducposer, had same thing happen to me today.
Only happened twice, minutes apart.
First time after I stopped to wipe the brake fluid off the reservoir.
Clutch reservoir hardly oozing today.
dharma is offline   Reply With Quote
Old Nov 2nd, 2011, 7:49 am   #6 (permalink)
DucDuk's Avatar
It started happening to me today as well. I figured that it was because it is cold out, 43 degrees F. My bike had a hard time starting as well - and I just unplugged it from my Battery Tender. So, I guess I will check it out for fluid leaks during lunch.
Rick
'10 Streetfighter S
'06 Kawasaki KX450F
'07 Husky TE450 (Sold)
'05 Honda TRX450R (Sold)
'95 Monster M900 (Sold)
'95 Suzuki RM125 (Bored to 144) (Sold)
DucDuk is online now   Reply With Quote
Old Nov 2nd, 2011, 10:10 am   #7 (permalink)
I dont think its the clutch because this happens while im on the freeway just cruising. Ill go get on the throttle and the bike will lag between the throttle and actual power delivery. Today im going to turn off the dtc on my commute and see if thats the problem.
BarF
I BarF
You BarF
We all BarF
Bayarearidersforum
Old Nov 2nd, 2011, 10:47 am   #8 (permalink)
Secret Squirrel's Avatar
Possible that the TPS is out of whack? Maybe you guys need a TPS reset?
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is online now   Reply With Quote
Old Nov 2nd, 2011, 11:43 am   #9 (permalink)
Well it's not the dtc. I turned it of and still had the problem. When I rev it the engine spins up (increases in rpm) but when the powered is delivered to the wheels the rpm drops, and then starts to climb again. When I want to speed up I have to gently get on the throttle and wait a sec
Will syncing the throttle bodies and resetting the tps help?!
BarF
I BarF
You BarF
We all BarF
Bayarearidersforum
Old Nov 2nd, 2011, 11:49 am   #10 (permalink)
A little more info. I have the DP slipper clutch, termi half system with ecu and air filter. Other than that the bike is bone stock.
BarF
I BarF
You BarF
We all BarF
Bayarearidersforum
Diavel Low Speed Fueling Iceman10 Diavel 3 Jul 9th, 2011 12:17 pm
Fueling changes with CCW 6.4 tank and pods? northsouth HyperMotard 5 Mar 1st, 2011 1:03 am
Fueling woes... bmartinek HyperMotard 7 Aug 26th, 2010 1:31 pm
Need some help with a fueling problem - engine is stuttering. colacin HyperMotard 8 Jul 18th, 2008 6:34 pm
My new 696...bad fueling? desmodrone Monster 16 Jun 25th, 2008 8:27 pm
