Leaking ohlins - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Oct 31st, 2011, 4:20 am   #1 (permalink)
Leaking ohlins
Hello guys
Yesterday I was looking at a black second hand streetfighter S
It's one off the firsts dated at 04-2009 and it has 13000km (about 8500 miles)
I noticed that the right hand fork was leaking.
The seller said he didn't noticed it before , but that he allready had to replace the left hand side seal last year , but it was under warranty.
I have heard it from "ducatisti" that the production ohlins have a bad reputation of oil leakage!
So here is my question at what price tag am I looking to get the job done
at a duc garage(I will offcourse deduct from his asking price) and is there a permanent solution for this problem , because I don't wanne change seals every 5000 miles or so.
cheers
Peter
pikfee is offline   Reply With Quote
Old Oct 31st, 2011, 8:27 am   #2 (permalink)
ltsnipe's Avatar
Originally Posted by pikfee View Post
Hello guys
cheers
Peter
I took my forks off for the dealer and brought them to them. They charged me one hour plus parts. Approx $200. I change both even though only one was leaking.
Carmen
2008 Ducati 1098S
2007 Yamaha R1 (182RWHP Track Slut)
2010 Ducati Streetfighter S (sold)
2007 Honda CBR1000RR (sold)
What you know about bacon...bitch?!
ltsnipe is offline   Reply With Quote
Old Oct 31st, 2011, 9:23 am   #3 (permalink)
flynbulldog's Avatar
fork seals leak. doesn't matter if they are production forks or the high-end racing forks -seals wear and then they leak.
There is no permanent solution and it will happen again. Get them fixed under warranty if you can.
But understand that it doesn't matter what brand of bike you own or what forks are on it this is part of life owning a motorcycle.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
74 Duc 750 sport special
66 Duc 250 NC racer
65 Norton Atlas cafe'
flynbulldog is offline   Reply With Quote
Old Oct 31st, 2011, 10:42 am   #4 (permalink)
I read you bulldog but the perticullary the ohlins have a bad rap over here
I have had plenty off motorcycle"s and mostly leakage appears at around30000 km
And my current bike is an f4 agusta 1000 mamba with 55000km (all ridden myself) with showa forks and still no leakage so far..
I think at 13000 km that both will allready have to be replaced not a thing that should happen , and evenmore at a top off the range suspension like ohlins should be.
I also go on my holidays with the bike (me and the boys living it out in the alps.)and if leakage suddenly occurs in a mountain road desend I would rather not think what could happen if oil reaches the tire or break disc.
cheers
Peter
Old Oct 31st, 2011, 10:59 am   #5 (permalink)
cheers
Peter
I don't know what you expect. Seals can leak at any time.
The forks on my MV Brutale were leaking at 1700 miles. Got them replaced under warranty.
I've owned Ducs with Ohlins for years and don't experience them leaking any more than other type of forks.
In fact I think I've experienced less frequent leaks with my Ohlins forks than with other brands.
Believe what you want but why ask for opinions and experience from others if you're just going to discount the answers you get?
The bottom line is that a leaking fork seal is not a good reason not to buy a bike unless you think the fork is damaged and causing the seals to wear prematurely.
If you don't want to buy a bike with the best suspension on the market because of some BS rumors then that's up to you.
I think you should let the dealer fix the seal and go enjoy the bike.
11 Multistrada 1200
10 Streetfighter S
89 GB500
73 Duc GT750
66 Duc 250 NC racer
Old Jan 11th, 2012, 1:09 am   #6 (permalink)
whoopazz1's Avatar
So my fork seals are leaking as well at 11000 kms on the bike. I have warranty on the bike still but doubt that my dealer will replace them as I see it as a wear and tear item.
My mistake to ask them if they are covered under warranty as I assumed they wouldn't be, but they quoted me $200 for seals and $400 for for seal package. Anyone know where I could get them for a bit less?
Not sure what the diff is between the two and parts guy didn't either...
Any input would be great.
But I will prob go talk to the service department and see what they say.
whoopazz1 is offline   Reply With Quote
Old Jan 11th, 2012, 4:29 am   #7 (permalink)
I have the same problem by 9800km. I will try to fix this at home.
Simeone is offline   Reply With Quote
Old Jan 11th, 2012, 9:29 am   #8 (permalink)
FlyingQ's Avatar
Just adding fuel to the fire here, but...
While your Ohlins specialist has them apart, you can have him upgrade the rebound dampening valve (there's an Ohlins kit for it) for about $350.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Jan 11th, 2012, 10:20 am   #9 (permalink)
Images: 44
My bike is one of the first in Europe, seals leaked at 25000 Km and then again at 33000. Some experienced people here say that it is better to change them with GSXR seals (dont know wich specific ones) that last a lot longer, but haven t done that yet.
springer1994 is offline   Reply With Quote
Old Jan 11th, 2012, 10:28 am   #10 (permalink)
One way to get a longer life out of a fork seal is to wipe down the fork tube after every ride taking care not to scratch the tube itself. Even with the fender covering the fork tube I find bugs find there way to the tube which could wear on the seal. Even with that, you will still be replacing seals. It's the nature of the beast.
2007 S4RT (RIP)
lardawge is offline   Reply With Quote
1198 SP Ohlins TTX shock/Ohlins OEM triple HarmonyJim Parts and Accessories 1 Jul 21st, 2011 12:14 pm
What is the difference between stock PS Ohlins and the R&T Ohlins. rocketbrothers540 Sport Classic 9 May 6th, 2011 9:00 pm
WTB:Ohlins bracket for 1098 Ohlins damper rocka Parts and Accessories 3 May 4th, 2011 7:11 pm
Ohlins SBK valved Ohlins forks & Shock JDuc Superbikes 9 Aug 3rd, 2009 5:30 pm
