Clutch installation removal HELP needed - Ducati.ms - The Ultimate Ducati Forum
Old Oct 26th, 2011, 2:15 pm   #1 (permalink)
Ive been going back and forth about installing my own slipper clutch. Anyway read loads of forums and guides and I have got so far and now I am stuck. I have removed the pressure plate, centre nut and hub and I am left with the attched pic. How do you remove this, the star shaped large hub thing? and what tools are required?
Any advice would be much appreciated.
2011 Ducati Streetfighter
2005 Ducati 748 - sold
2002 GT aggressor mountain bike
2001 Honda CBR600F - sold
1999 Suzuki SV650S - sold
Mrsmith is offline   Reply With Quote
Old Oct 26th, 2011, 3:59 pm   #2 (permalink)
Ducati Designs
pgeller's Avatar
Images: 26
Odd that the cush drive of the hub came apart; normally it stays together and you just pull the hub off the spline. No matter, its just a good fit to the splined shaft, so a bit of penetrating oil, heat and some tugging should get it loose. If not, you could (carefully) try a gear puller.
pg
DD
pgeller is offline   Reply With Quote
Old Oct 26th, 2011, 4:02 pm   #3 (permalink)
troubled otter's Avatar
The only way I could get mine off was find the biggest Alan key that you can hook behind it by sliding it in the gap and turning it 90 deg. Then I put a mole grips on the other end of the Alan key and tap it with a hammer. I did this all the way round the edge and eventually it came off.
Hope this helps mate.
Street fighter S,ST 4 Radical project,ST4S,Monster 696,Triumph 675 daytona SE.
troubled otter is offline   Reply With Quote
Old Oct 26th, 2011, 4:09 pm   #4 (permalink)
Thanks for the replys im going to try the oil and a little elbow grease ill post if i manage to sort it
Old Oct 27th, 2011, 7:33 am   #5 (permalink)
WNM
Troubled otter's method sounds a bit less invasive than my method but I spot welded one of the hooks from my puller to it the hooked it up to the slide hammer and it popped right off. Need to be real careful with the heat though.
WNM is offline   Reply With Quote
Old Oct 27th, 2011, 8:28 am   #6 (permalink)
DucDuk's Avatar
OK, not knowing much about the slipper clutch setup - understand the theory though - can you still run an open clutch cover when using a slipper clutch?
Rick
'10 Streetfighter S
'06 Kawasaki KX450F
'07 Husky TE450 (Sold)
'05 Honda TRX450R (Sold)
'95 Monster M900 (Sold)
'95 Suzuki RM125 (Bored to 144) (Sold)
DucDuk is online now   Reply With Quote
Old Oct 27th, 2011, 9:21 am   #7 (permalink)
FlyingQ's Avatar
Absolutely.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Oct 27th, 2011, 10:22 am   #8 (permalink)
I was wondering about the heat. Was planning on using a heat gun but was worried that I perish the rubber O rings inside?
Old Oct 27th, 2011, 10:45 am   #9 (permalink)
Try the allan key mate. It will work. What slipper you fitting then?
Old Oct 27th, 2011, 12:39 pm   #10 (permalink)
Managed to get it off eventually. Used mole grips to hold onto one of the stars and then hit the end of the grips with a hammer away from the bike to pull it off. Took a few hits and I was creful to cover the bike with sheets first but it worked. Oh I did spray sum WD40 on before hand and let soak overnight. Not sure if this made any difference though.
Duc.EE Installation and Servo Motor Removal Northlight Multistrada 10 Dec 19th, 2011 9:40 pm
Wheel Removal & Installation Shazaam Hall of Wisdom 11 Oct 15th, 2010 1:10 pm
Termi 2-1 installation instructions needed... Willi-P HyperMotard 6 May 11th, 2009 11:57 pm
Starter installation on a Corsa, What's needed? Motobee Superbikes 0 Apr 25th, 2007 2:12 am
Exhaust Question; Removal and Installation? ducatiti Supersport 11 Sep 6th, 2006 6:33 pm
