Garbage disk bolts - Ducati.ms - The Ultimate Ducati Forum
Old Oct 16th, 2011, 7:20 pm   #1 (permalink)
samw5's Avatar
Garbage disk bolts
Is it just me or the front disks bolts are total POS.
Tried to take the disks off, these things are so retarded tight that it's either fucking up the stupid torx (who fucking uses that on bolts that require over 80lb/ft of torque???) or bending the crappy ass torx bit!
Anyone has any idea what type of torx bit could be used to get these bolts off? Tried forged bits, tried forged bit on an impact, already stripped two, I think I'm gonna bright this to my dealer and throw it at their face for making this so retarded hard to remove!
2010 SF tricolore.
samw5 is offline   Reply With Quote
Old Oct 16th, 2011, 7:27 pm   #2 (permalink)
Best bet is to use a quality bit without impact, unless all lesser means have failed. Long hadled wrench or breaker without extensions. Make Sue you keep it square and tight in the fastener.
iguanamafia is offline   Reply With Quote
Old Oct 16th, 2011, 7:32 pm   #3 (permalink)
Expand the mind. Not a fuel tank
Wonway's Avatar
An impact driver is what you want. Use something like this with a good socket.
Wonway is offline   Reply With Quote
Old Oct 16th, 2011, 7:33 pm   #4 (permalink)
I find using a bit of heat will work wonders on brake disc bolts and they are not torqued to 80ft lbs, though it does seem like it, I believe they are torqued to 25ft lbs? with some thread locktight(not sure of which strengh)
motodave is offline   Reply With Quote
Old Oct 16th, 2011, 7:55 pm   #5 (permalink)
Secret Squirrel's Avatar
In this case I would use a good bit and an air impact. These bolts are torqued and may have some lock tight on them. Using a breaker bar on these is not good. You might be physically strong enough to break them loose, but the torques part of the bolt may start to give way. The jolting action of an air impact makes easy work of this without damaging the head of the bolt.
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is online now   Reply With Quote
Old Oct 16th, 2011, 8:10 pm   #6 (permalink)
Wonway's Avatar
This thread was brought to you by post #3
Don't use an impact gun and don't use a breaker bar and don't use heat. I'm tellin' ya, don't do it.
Old Oct 16th, 2011, 8:22 pm   #7 (permalink)
samw5's Avatar
Ya they are supposed to be at 25 but there is NOWAY they are at least not on my bike. I bet the confused the antiseize with locite!!!
I guess I'll have to wipe the heat gun out, really didn't want to have to fuck around with it this much... And these bolts are garbage.
2010 SF tricolore.
Old Oct 16th, 2011, 9:00 pm   #8 (permalink)
Wonway does have a point here. The hand hammer impact is a good tool. If I where to use an air impact you really have to push on the impact very hard and pulse the trigger. Almost the same action as the hand hammer impact. I have used both methods before with success. I have both tools in my box.
Old Oct 16th, 2011, 9:20 pm   #9 (permalink)
FlyingQ's Avatar
I've not had any trouble with these particular fastners. I use Craftsman Torx sockets. I'd follow what motodave had to say...use a little heat (not flame or fire). Here's some more info if it'll help. Cheers.
From the maintenance manual:
Brake disc retaining bolt M8x1.25 24* DRILOC 218 for original use to BREMBO for replacement parts LOCK 2
That's 24 Nm +/- 5%.
This is from The Loctite Technical Data Sheet For Product 218:
PRODUCT DESCRIPTION
LOCTITE® Product Dri-Loc® 218 is a low to medium strength
pre-applied threadlocker. The pre-applied film is dry-to-the-touch
and remains an inert coating until assembly. During assembly
microcapsules, which are contained within the coating, are
crushed thereby releasing an active ingredient which initiates the
curing process
Torque Augmentation
Breakloose torque of an uncoated fastener will normally be 15 to
30% less than the on-torque.
2010 Streetfighter S
2000 Monster 900S
2004 749S (gone)
2003 Monster 800Sie (gone)
FlyingQ is offline   Reply With Quote
Old Oct 16th, 2011, 9:57 pm   #10 (permalink)
samw5's Avatar
Hmm, I guess I'll try the heatgun... Not question mine was way tighter than 25, I've almost busted my knuckles trying to get them out.
Thanks for the tips though.
2010 SF tricolore.
More brake disk application questions BrianG Superbikes 6 Sep 13th, 2011 4:38 pm
Brake disk decision desmo_pt Superbikes 8 Dec 2nd, 2010 6:47 am
God damn marelli garbage OldSkoolCool Sport Classic 1 Sep 14th, 2008 10:08 pm
The Haynes Supersport manual is GARBAGE! Blackducati750 Supersport 12 Jul 7th, 2008 5:23 pm
Decontaminating disk brakes YellowDuck Sport Classic 2 Apr 4th, 2007 3:11 pm
