Lubricate the clutch centre? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 15th, 2011, 4:05 pm   #1 (permalink)
MrQ
The service manual says "Lubricate the clutch centre" at 24.000 km. What does it mean?
Is it referring to the ball barring in the centre of the pressure plate? What do I use for lubrication oil or grease?
I guess I have to be careful only to use a small amount or I will destroy mu clutch.
2009 Streetfighter
2005 R6 (Sold)
2005 R46 (Stolen)
2000 SV650S (Sold)
MrQ is offline   Reply With Quote
Old Oct 15th, 2011, 5:34 pm   #2 (permalink)
The release bearing is a sealed unit, and it's inexpensive. I'd just replace it rather than try to lube it. Get one from your local bearing supply house rather than from your dealer because it will cost less. Take the old bearing with you so they can match it. It's a "6201 2RS".
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Oct 16th, 2011, 4:52 am   #3 (permalink)
I saw a you Tube vid of a clutch service on a 748. He recommended taking out the clutch rod nd greasing the end. The put it back in approx inch and spin the rod to lube the inside close2where yr bearing and clutch plate are going to sit once fitted. I might b wrong but if you have it off might as well.
Edit-
http://vimeo.com/m/8401825 this is useful nd even though it's for a slipper the principle is the same.
Mrsmith is offline   Reply With Quote
Old Oct 16th, 2011, 2:52 pm   #4 (permalink)
MrQ
Allright. I didn't know it was a sealed bearing. I will just take you advise and change it when it dies.
Thanks.
2009 Streetfighter
2005 R6 (Sold)
2005 R46 (Stolen)
2000 SV650S (Sold)
New vs Old MTS1200 centre stand Kitesurfer Multistrada 11 Dec 28th, 2010 5:34 pm
Centre stand for a 1100 snap25 Multistrada 1 Sep 2nd, 2010 10:37 am
Clutch Rod,Clutch Plates Clean & Lubricate ?.?.?.? spud0611 Superbikes 2 Dec 10th, 2008 9:06 pm
996 with Hub centre steering.... DukeDesmo Superbikes 2 Apr 11th, 2008 2:44 pm
Centre stand Hootie6670 Monster 1 Aug 27th, 2007 8:03 am
