You can confirm DTC being active just by running the DDA and checking the data runs. Sometimes it is not evident that DTC is intervening since you are looking at the road and not the dash... I was under the impression that whenever DTC triggered, you got either one of the two different dash flashes. Are you seeing the dash light up showing DTC intervention? By what I'm saying, I do not know if DTC is intervening at lower levels and not displaying on the dash, if that makes sense.
I do recall you post in the past on the MotoLab flash. If they are near you, and can also offer follow up, maybe that is a good choice. You can't enjoy the bike in stock fueling. It just ends up pissing you off (IMO). SO be it MotoLab, tuneboy, Lofgren, REdline etc... you just have to pick your poison.
