termi slip on self install - Ducati.ms - The Ultimate Ducati Forum
Old Oct 6th, 2011, 6:00 pm   #1 (permalink)
Hi all,
Quick question,
Got a termi slip on kit and just waiting for the initial break in before I put them on (400km so far). My question is... if I install the slip ons and ECU myself will this cause any warranty issues? I mean if something was to go wrong down the track will Ducati want to know if the slip ons were installed by a certified installer etc....
I have read the how to's on the installation and Im not a muppet when it comes to wrenching, it seems pretty easy and straight forward so I would really like to give it a try.
Thanks
philjt is offline   Reply With Quote
Old Oct 6th, 2011, 6:15 pm   #2 (permalink)
Gilly's Avatar
Images: 17
If you install the parts correctly, you should not have any issues. If you install the parts incorrectly, then you would have an issue.
Many people dont even wait for supposed break in to put the Termi's on. Some have them installed at time of purchase. It will not change how the bike breaks in. How a bike breaks in is all in the wrist and the rpm's.
Once installed, the bike should be adjusted for the new pieces as in a standard tune up check. If the install went fine and the bike runs fine and doesn't run too lean or too rich, just ride to dealer for a TPS reset and CO reading. If not, or you don't feel comfortable with that... trailer it on in and have that done.
As always, talk to your dealer. Tell them what you are doing. Check out what they would charge for the install / set up versus just the set up.
"Oh My!" thread link... FFS!
Old Oct 6th, 2011, 6:23 pm   #3 (permalink)
Cool thanks for the advice, will take it on board.
Old Oct 6th, 2011, 7:00 pm   #4 (permalink)
Is there anything I should know before I do the install which is not detailed in the how to's?
Like pastes or threadlocks? I have been told to make sure I have anti seize paste on the bolts. Do the slip ons literally slip on? Do you need some kind of a gasket or paste?
Thanks
Old Oct 6th, 2011, 7:25 pm   #5 (permalink)
Secret Squirrel's Avatar
The Termis are just slip ons that use springs just like the stock mufflers do. Other slip ons for the SF are the same way. No clamps are needed from the muffler to the OEM header. The slip joint can be tight. One of the slip joints on my bike is tight.
2011 Ducati Streetfighter S
2004 Triumph Speed Triple SE
1999 Suzuki Hayabusa
1996 Suzuki GSXR-1100-Sold
2001 Suzuki TL1000R-Sold
Secret Squirrel is online now   Reply With Quote
Old Oct 6th, 2011, 8:33 pm   #6 (permalink)
Gilly's Avatar
Images: 17
Did you get an ECU with the slip ons?
I was assuming you did. If it is just putting cans on the bike, 99.999% of people should be able to do that!
If you were installing cans and the ECU, then certain things must be understood about swapping ECU's. Still 99.888% should be able to swap the cans and ECU.
- Remove passenger seat/tail cover
- Open battery compartment cover
- Disconnect battery (it may be helpful to just put a tab of painters tape on the battery terminals to prevent the cables from "wanting" to touch the terminals.
- Remove main seat
- Pull fuse block up out from behind the ECU
- Release two ecu cables from ECU
- Unscrew two hex bolts securing the ECU
- Remove ECU
- Be aware of the ECU ground wire on the left side, it must be attached in order for the ECU to work
- Install ECU and do everything above in reverse order (dont forget the ground wire)
- Have a beverage
Old Oct 6th, 2011, 10:00 pm   #7 (permalink)
- Remove main seat
- Remove ECU
- Have a beverage
Cool,
I like the sounds of that last step.
Thanks once more
Old Oct 6th, 2011, 10:06 pm   #8 (permalink)
pcoakle1's Avatar
Gilly, good description....
- Remove main seat
- Remove ECU
- Have a beverage
2010 Ducati Streetfighter S
2009 Yamaha YZ450F
pcoakle1 is offline   Reply With Quote
Old Oct 7th, 2011, 11:42 am   #9 (permalink)
When changing out an ECU, a TPS reset is mandatory. It may or may not run good enough to ride to the dealer for the reset. You can change out the cans and ride to the dealer with the original ECU, then have him do the swap and TPS reset. It's about a half hour job, so you might be able to have it done while you wait.
'09 Kaw Versys
'00 Kaw KLR650
USN Vet.
ttpete is offline   Reply With Quote
Old Oct 8th, 2011, 3:22 am   #10 (permalink)
- Remove main seat
- Remove ECU
- Have a beverage
Excellent advice, expecially earthing the ground wire which I over looked as it is very easy to miss!
Mrsmith is offline   Reply With Quote
Leo Vince Slip on Install HELP!! CarbonTard HyperMotard 1 Aug 13th, 2011 9:03 am
DP termi 2-1 install PDF and DP tank bag install PDFs ... johnchypermotard HyperMotard 2 Apr 27th, 2010 7:00 pm
Termi slip-on install q? PedroHM HyperMotard 8 Jun 11th, 2008 4:16 am
Termi slip on or shark slip without changing ECU elementfmfl Sport Classic 4 Dec 31st, 2007 7:47 pm
Install Termi slip on? pchmotoho HyperMotard 9 Aug 15th, 2007 11:12 pm
