Like almost everyone on the Streetfighter forum, I wanted a solution to the 3500 rpm rough spot. I've had a 14t front sprocket, FatDuc O2 manipulators, and a PCV on my SF-S which has Termi slip-ons, DP ecu, high flow air filter, and DP carbon air ducts.
None seemed to work well enough. The PCV, at least on my bike, couldn't tune in the closed loop area below 5k rpm and the FatDucs created a rich situation around 3-3.5k rpm causing my exhaust tips to be very sooty.
I contemplated using a ProTune since I already had the PCV, but Dave Lillard from my dealership Redline Performance Motorsports asked me to wait because he had something brewing...
What Dave did was decide to learn about the Magneti Marelli ecu. He's an engineer by trade, so he flew over to Germany in November and took a course on the Marelli, learning the hex programming codes.
He discovered that Ducati was limiting horsepower in the first three gears while the last three gears had access to all available hp. Dave reprogrammed my ecu last Saturday, and boy is there a difference! He created a custom map and freed up the hp in the first three gears and of course got rid of the O2 sensors so he could tune throughout the full rev range.
The bike is amazing! It is smooothhhh... It is also crazy powerful! I went from 137.05 rwhp with 73.74 ft/lbs tq to 155.3 rwhp with 85.27 ft/lbs tq. Check out the dyno chart.
Needless to say, I'm ecstatic! My SF is transformed. If anyone needs their ecu reprogrammed, I suggest you give Dave a call (757-989-5000). No need to buy an aftermarket ecu when he could change your existing one. Apparently, Ducati USA has sent him some ecu's to reprogram and he also reprograms Siemens ecu's.
Btw, Dave is such a cool cat. Not only is he the owner, he's the suspension expert, and the tuner. You could always find him in the shop working on bikes. The dude also leads the group rides!
