PCV Maps for Streetfighter - Ducati.ms - The Ultimate Ducati Forum
post #1 of 33 (permalink) Old Jan 6th, 2011, 2:05 am Thread Starter
Sputniks's Avatar
This Friday the bike is scheduled for a Power Commander and its associated AutoTune module installation (AutoTune is an additional electronic device that works in conjunction with Power Commander).
For a better and a quicker result it is recommended to pre-load a map (PCV) that is close to the current bike's configuration.
Unfortunately there are only two maps available on PC web site. I wonder if there are any links to download-able maps for Streetfighter. Or may be there is anyone who has a bike with a configuration similar to mine which is a Full Termi exhaust system+DP ECU+DP Air Filter and DP carbon fiber oversize air ducts (intakes).
Sputniks is offline
post #2 of 33 (permalink) Old Jan 6th, 2011, 3:18 am
direktor's Avatar
Make sure you get a map for the slipper clutch too.
'86 GSXR-750
'91 FZR-600
'09 M696
'10 Streetfighter
direktor is offline
post #3 of 33 (permalink) Old Jan 6th, 2011, 8:16 am
SquireSCA's Avatar
I have a custom twin cylinder map that was made on a Dyno for my SF. It had the Termi slipons, DP air filter, modified intakes, etc... Was making just under 149hp at the wheel on my bike.
Shoot me an email address, or I will see if I can upload the map here for anyone who wants it.
That should be the map, I don't have the DJ software installed on this machine to check it, let me know if it is the right one. The Dyno chart shows the difference of back to back runs with the airbox modded and without.
Name:	2010 Ducati Streetfighter airbox mod.png
File Type: zip Nixon10DucStreetfighter.zip (668 Bytes, 60 views)
- 2009 Ducati 1198
- 2011 Triumph Speed Triple 1050
SquireSCA is offline
post #4 of 33 (permalink) Old Jan 6th, 2011, 11:22 am Thread Starter
Sputniks's Avatar
Thanks for the map David! I really appreciate it.
Director, after a few months on Ducati.ms forum it became quite difficult for me to see when it is a joke or not. Sorry if I misunderstand anything.... but are you serious about a slipper clutch and the map? What is the relationship between a slipper clutch and air/fuel mixture map? I thought the only parts that are involved here are the ECU, exhaust, intakes, the airbox, a quick shifter and may be some other mods that are directly involved to intake/exhaust line. Please correct me if I misunderstand anything.
Sputniks is offline
post #5 of 33 (permalink) Old Jan 6th, 2011, 11:30 am
SquireSCA's Avatar
He is joking.
Personally, I don't like the automapper. It sounds good on paper, but they never seem to give results that are as good as a custom map.
Try my map, if it feels like it is pretty dialed in, return the autotune and get your money back.
- 2009 Ducati 1198
post #6 of 33 (permalink) Old Jan 6th, 2011, 1:52 pm
fighterpilot's Avatar
Sputs,
What are you using in conjunction with the PCV to allow you to tune below 5k rpms?
Black 2014 Speed Triple R
White 2010 Streetfighter (sold)
-you only live once, and I feel like I'm running out of time...
fighterpilot is online now
post #7 of 33 (permalink) Old Jan 6th, 2011, 3:23 pm
Temporary greeter
Wonway's Avatar
Originally Posted by oahu 'fighter View Post
Sputs,
Throttle blipping
Wonway is offline
post #8 of 33 (permalink) Old Jan 6th, 2011, 3:36 pm Thread Starter
Sputniks's Avatar
Sputs,
While an opinion that DP Ecu that comes with full Termi exhaust system doesn't let to tune below 5K RPM is quite popular I still would like to see if that opinion is correct by installing the Power Commander with Autotune.
Sputniks is offline
post #9 of 33 (permalink) Old Jan 6th, 2011, 4:01 pm
IHMC Est. 2010
freezerburn's Avatar
Sounds like a good plan Sputternuts. You obviously have more money than you need and as far as scientific protocol goes, it is good judgement to repeat the very same experiment just to see if the results will be different. You are such a skeptic you little rascal
F1098S 'F' is for 'freezerburn', 'S' is for 'sick'
freezerburn is offline
post #10 of 33 (permalink) Old Jan 6th, 2011, 4:27 pm Thread Starter
Sputniks's Avatar
I just want to make my bike faster then yours.
Sputniks is offline
Human Verification
2009 Streetfighter Comparison: 2010 Ducati Streetfighter vs. 2008 Benelli TnT 1130 admin Ducati.ms News 0 Dec 1st, 2009 10:09 am
maps maps maps - 2-1 exhaust and velocity stacks--no filters barfer Sport Classic 2 Oct 28th, 2009 8:13 pm
PCIII maps? jeremyh007 Superbikes 1 Jul 30th, 2009 6:59 pm
Nemesis Maps SAC Superbikes 12 Nov 7th, 2008 4:54 pm
powercommander maps??? bdp Superbikes 1 Jan 29th, 2008 2:49 am
