748/916/996 parts
Time to clean out the basement.
Triple with all bolts, bearings. off stock 748 for showas and adjustable head frames.(replaced mine with 749R triple) $150
Battery box $10
chain cover no brake line cover. $5
Rear Wire Harness ( missing one taillight connector) $10
Gauge pod no gauges but idiot light subharness $10
Tach subharness $20
Gauges pod with temp and tach both subharnesses (the two screws that hold the faceplate in the tach have somehow come loose inside. I do not know that this can be fixed. It functions fine other than the face bouncing a bit at high RPM. $100
Tail lights completely stock with bulbs $20
Tail light with turn signal integrator from evoluzione, it is not led but uses normal bulbs. Bulbs included. It is set up to plug in without modifying your harness. $30
Seat stock monoposto seat no rips, no sunfade, all mounting posts and screws are perfect. $60
Ride height adjuster stock with free nonstuck joints $10
I have misc brackets. The one pictured will go with the battery box, please email with needs. More pics can be sent per request. All prices above are plus shipping, quotes provided as needed. Please PM me with your email. Thanks Brad.
