$500 + actual shipping
These triples come off my 998. The Speedymoto upper was one of their first batches and as such the little top piece is silver and not anodized red. The lowers came with a set of R&T forks I purchased from the old Track Junkie bulletin board. The Arrow Titanium damper I purchased off eBay. Steering stem is stock from my 2002 Ducati 998. All parts function perfectly together.
The steering damper rubbed the tank slightly on my 998 when first mounted. Scotty at Desmoto re-machined the Speedymoto upper mounting point to space the end of the damper out. I tried to capture it in the photo but my camera's abilities are limited (mostly by my lack of brains). You cannot tell a thing once the damper is mounted.
Also, the Arrow damper has a hairline crack barely visible on the outer "eye" of the distal mounting point. I tried to photograph this as well.
I prefer to sell the entire set-up as a package as I know that all the parts fit together and function perfectly. Standard offset, standard openings (53mm top and 56mm bottom, if I recall correctly). Only selling because I got a deal on some Nichols 30mm offset triples for my 998R build.
PM me with a phone number if interested.
Thanks,
Ken
Triple A by
Rotted_Melon, on Flickr
Triple B by
Arrow A Side by
Arrow B Side by
Arrow End by
