Wanted: 999 OR 998 in good condition - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Classifieds > Bikes
Old Jan 16th, 2012, 12:26 am   #1 (permalink)
415m3's Avatar
Yeah, I know....different animals, but what can I say? I like both and am jonesing to get back on a bike. Prefer mono, red, with minimal mods. Pretty open minded though. I'm in SoCal and hoping to spend under $8000.
What have you got?
Past rides:
2006 ST3
2003 999
1999 996
1998 M900
1995 900SS/SP
415m3 is offline   Reply With Quote
Old Jan 31st, 2012, 11:21 pm   #2 (permalink)
replied.
dwu819 is offline   Reply With Quote
Old Feb 23rd, 2012, 2:37 am   #3 (permalink)
Got a Mono, red, 03 999 with Termi slip-on
Mods as follows.
Carbon:
Exhaust cover
Ex. pipe guard
Heel guards
Air runner covers
Belt Covers
Inlets
Black rims, pazzo shortys, Not much else. PM me for details.
Cardi is offline   Reply With Quote
Old Mar 25th, 2012, 9:37 am   #4 (permalink)
Black Red and White super trick 998
This bike has been highly modified and maintained, it last dyno’d 140HP and 80ft lbs of torque at the tire. The motor was built by Lauren and Mark at the DucShop. This bike has been serviced at the DucShop since the motor was built 5 years ago. The last three years have not seen much use as I have been deployed multiple times. The bike has been tuned by Former Head mechanic for HMC Ducati Race team Mark Sutton. This is the list of the modifications to the bike.
998R Camshafts Intake and Exhaust sets
Pistons (Hi Compression)
Valve and cylinder head stage 1+ work (Lauren at DucShop)
Termignoni Corsa Titanium (tubes and silencers) 60mm full system
998RS Corsa coolant tank
998RS Corsa Radiator
998RS Corsa radiator hoses silicon and aluminum tubing and cylinder head pieces
998RS MS Productions Carbon Fiber timing belt covers vertical and horizontal
998RS Corsa Oil Cooler
998RS Corsa undertail large breather box with proper hosing and valve in airbox
Lightened Flywheel (DucShop)
Blueprinted Engine (DucShop)
Microtech engine management computer
Custom dual cylinder dyno map by mark sutton at Ducshop
Ducati Racing slipper clutch w/ball bearings and lightweight clutch basket
Cyclecat billet clutch cover
Cyclecat billet long sidestand
Ducati Perfomance (MS Production) Corsa large carbon fiber breather box
Ducati Corse crankcase breather
Ducati Corse airbox /breather valve
Ducati Perfomance (MS Production) front carbon fiber wheel fender
Ducati Perfomance (MS Production) headlight bucket 998
Ducati Perfomance (MS Production) upper fairing supports 998
Ducati Perfomance (MS Production) 748RS/996RS rear fairing race support
Ducati Perfomance (MS Production) carbon fiber upper front fairing 998
Ducati Perfomance (MS Production) carbon fiber 998RS large airtubes
Ducati Perfomance (MS Production) carbon fiber 998R rear fairing
Ducati Perfomance (MS Production) 998RS carbon fiber exhaust guard
Ducati Perfomance (MS Production) Race swingarm guard
Ducati Perfomance (MS Production) race chain guard
ETI Carbon Kevlar RS fuel tank with breather
Billet black anodized race fuel cap
Composite Carbotech 998R Side fairings
Carbon Kevlar 998R oil pan
Carbon Fiber front sprocket cover
Carbon Fiber 998RS rear set guards
Fast By Ferracci clip ons
Magnesium Corsa Swingarm
Magnesium rear hub
Magnesium Marchesini wheels 6” rear
Ducati Race rear axle for full floating brembo disc
Ducati Corse ride height adjuster
Ducati Corse dual position shock pivot
Ohlins rear shock with superbike internals and valved for racing swingarm (DucShop)
Ohlins fron forks w/superbike internals (DucShop)
Ohlins stearing dampener
Ducshop 27mm offset triple set (lightweight)
Brembo 34/32 narrow band calipers with titanium hardware
Brembo superbike narrow band rear caliper
Brembo narrow band corsa front 320mm cast iron rotors
Brembo narrow band corsa rear 200mm rear rotor
Brembo billet clutch master cylinder
Brembo GP 19x18 front brake master cylinder with brake light switch
Fren Tubo Kevlar front brake lines
Fren Tubo Kevlar clutch line
Fren Tubo Kevlar rear brake line
Yoyodyne clutch slave cylinder
Euro left hand control switch with light off switch
Ducati Performance Rear sets
Cycle cat reverse shift lever (adjustable)
Speedcell 3 row lightweight battery
Key eliminator switch
Lightweight bolts and nuts Titanium and aluminum throughout the bike including
Timing belt covers
Shock upper pivot
Shock lower pivot
Shock linkage bolts
Ride Height pivot bolt
Sidestand mounting bolts
Rear brake mounting bolts
Rear brake clevis
Floating pins for rear brake disc
Front fairing bolts
Radiator guard bolts
Front brake disc bolts
Caliper pinch bolts
Caliper mount bolts front
Bolts for brake and clutch resevoirs
Bolts for clip-ons
Headlight adjustment bolt
Rear swing arm pivot and bolt
Front axle and nut
Fuel cap mounting bolts race
Bolts for upper fairing retention
Bolts for airbox
Bolts for subrame
Bolts for exhaust mounts
Rear wheel large bolt with cone (Al)
Lots of other bolts and nuts to mention
998R MS Productions Carbon Airbox
All dzues fasteners for fairings
Silverstar headlight lamps
AFAM quick change rear sprocket set (Black)
Frame professionally powdercoated gloss black
Including
Ducati Performance Aviofiber rear race fairing (Black) with seat
Ducati Performance Carbon/Kevlar race front fairing )black/red/white plate
Ducati Performance tall smoke windscreen with TI bolts
Pitbull front underwheel stand
Pittbull front under triple tree lift
Pittbull rear wheel stand right
Pittpull rear wheel stand left
Ride height adjustment tool
Front triple tree removal tool
Ducati factory camshaft 998 tool
Ducati factory crankshaft tool
Ducati clutch removal tool
Factory Tool set
Factory Ducati 998 Service Manual (factory printed in binder with document protectors)
Printed parts manual
Printed owners manual
748/996 Haynes manual
Ducati Performance Magnesium side cylinder head pieces (vertical and horizontal)
97Duc748 is offline   Reply With Quote
Old Mar 25th, 2012, 1:10 pm   #5 (permalink)
DucatiMilo's Avatar
02 998 feeler
DucatiMilo is offline   Reply With Quote
WTB, WANTED OEM Front seat 1X98, 848 in good condition motorcyclepimp Parts and Accessories 1 Oct 21st, 2011 11:12 am
WTB: Stock Clutch Cover in Good Condition PaulST4s Parts and Accessories 2 Aug 5th, 2011 10:16 am
Wanted Ducati EZ UP in good condition ymj0783 Parts and Accessories 2 Jun 5th, 2011 9:58 pm
WTB: xx9 passenger seat, new or used in good condition elliottw Parts and Accessories 3 Sep 2nd, 2010 9:22 am
Wanted race sport any condition Racer20 Sport Classic 0 Apr 7th, 2008 8:47 pm
