1998 900 ss fe #259 - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Classifieds > Bikes
Closed Thread
Old Oct 11th, 2011, 7:46 pm   #1 (permalink)
ducseeker's Avatar
1998 900 ss fe #259
I have a decided to put my FE up for sale. After buying the 999S this summer, the FE just doesn't get enough exercise.
If you search my posts here, you will find that I was having trouble with overflowing float bowls. The float valve needle turned out to be the culprit. So the bike has:
* New carb seals and float needle valves
* New spark plugs
* New fuel lines (from under the tank to the fuel rail)
* New fuel filter
Earlier in the summer I did some other work:
* Braided brake and clutch lines
* New timing belts
* Valve clearance checked - OK. (The vertical exhaust closer will need a new shim soon. Right on the tolerance edge.)
Other upgrades done previously...
* Penske double clicker shock
* Upgraded battery terminal and ground wires (Powerlet)
* K&N filter and open airbox
* Carbon fiber high mount exhausts (Giaccomo?)
The bike is not a garage queen; I rode like it was meant to be ridden. Didn't thrash it by any means, but the bike is just damn fun to ride.
Also, the previous owner had the battery puke on him and that caused some paint staining and peeling on the left side on the frame and engine case. But the affected area is behind the bodywork and is only visible if you look for it.
The paint on the bodywork is nice and glossy, but has a few scratches and paint chips here and there, nothing terribly obvious. The carbon fiber fenders (front and rear) could use a shot of clear coat. I am the world's worst painter, so haven't attempted to do this.
The bike has some mismatched fasteners that I didn't bother to replace. Several aftermarket options to choose from if you care.
The PO had the engine completely torn down in Aug '09 due to some dodgy main bearings. Main bearings, bushings, rod bolts & bearings were all replaced. Work was done by a local mechanic that I know and have used for my other bikes. This happened at around 10k miles, I estimate. The bike now has just over 13k on the odometer.
Lemans1 is coming to look at the bike this weekend, but thought I'd post this up just in case.
Asking $4250. I have a trailer and can deliver a short distance if necessary, but I would prefer not to deal with shipping. If you want to fly into DTW and ride her home, that's an option for a short while longer.
'06 999S
'06 749 (Track)
'05 Multistrada 1000DS
'98 900SS FE (SOLD)
'01 SV650 (Track - SOLD)
'03 M800ie (SOLD)
ducseeker is offline
Old Oct 11th, 2011, 8:52 pm   #2 (permalink)
oalvarez's Avatar
very original/stock and very clean.....very pretty as well
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
oalvarez is offline
Old Oct 12th, 2011, 10:19 pm   #3 (permalink)
NAO
NAO's Avatar
Nice ride! Where is it located?
NAO is offline
Old Oct 13th, 2011, 4:37 pm   #4 (permalink)
ducseeker's Avatar
My garage...in a Detroit suburb.
'06 999S
'06 749 (Track)
'98 900SS FE (SOLD)
'03 M800ie (SOLD)
Old Oct 14th, 2011, 6:04 pm   #5 (permalink)
NAO
NAO's Avatar
Bit far for me. Nice bike!
NAO is offline
Old Oct 15th, 2011, 1:25 pm   #6 (permalink)
ducseeker's Avatar
SOLD!!! Thanks, Dale. Enjoy the bike. I hope to see it out in Stockbridge next spring with those FCR carbs on it.
'06 999S
'06 749 (Track)
'98 900SS FE (SOLD)
'03 M800ie (SOLD)
Closed Thread
WTB: 1998 ss/fe Joe-B Bikes 12 Aug 25th, 2011 12:37 pm
?????1998 916????? desmotimmy Superbikes 4 Aug 11th, 2010 4:19 pm
1998 900 Ss/cr racerboy Supersport 37 Feb 19th, 2007 1:56 pm
i have a 1998 916 w/ a 955 kit and..... ducati955 Superbikes 5 Jan 17th, 2007 8:22 pm
looking to buy a 1998 748 color-rado Superbikes 7 Mar 3rd, 2006 10:38 pm
