I have a 996 track bike for sale $9500.00 or trade for a 6th Gen Honda VFR 800 plus cash.
This bike was built from the ground up. Body work says 748, but it is a 996. Bike was in a minor low side. I have replacement for the clutch cover.
996 engine dyno at 130HP without breather box. I've added the breather box in May I'm sure it makes more power now. Engine had 2800 miles stock, it has been mod Sept of 2010 has seen 4 track days since.
Engine built by Seacoast Sport Cycles have paper work.
Suspension set by GMD Boston sprung for 165lbs rider.
FBF hi-compression pistons
V2 cams same as SPS cams
Nichols flywheel
STP slipper clutch
Nichols 28MM triple
Ohlins damper rebuilt this May
Ohlins R/T forks
Penske triple clickers shock
Marvic 5 spokes magnesium wheels
Magnesium swingarm w/linear rocker
Magnesium eccentric
Arrow 50MM half system
Brembo 16x8 clutch master w/folding lever
Brembo 18x19 brake master w/folding lever
Brembo HP floating rotors (new with 1 track day)
DP carbon air box
DP carbon air runner
Vortex fairing stay
999R calipers with Carbone Lorraine race pads
Aluminum subframe
PC III
STI breather
Carbon undertail breather box
MPL clutch slave
DP carbon front fender
DP carbon v-cowl
Axlejak water pump cover
Slingshot Racing rearset GP shift
Woodcraft clip on
Lighten rear rotor
TPO front axle
TPO titanium engine bolts
TPO titanium swingarm pivot bolt
TPO titanium front axle spacer
TPO titanium bolts/nuts in suspension and rear sprockets wheel nuts(worth $600)
Frame does not have a title and it is not stolen. I have a 748 frame with clean title that I will include, if you are concern about the existing frame.
Levers are scraped but I have new replacement. Only the bodywork will be left as is.
www.drt-sport.com
1198S Track
1098 Track
996 track bike parted out
748 track bike patted out
2002 S4 (6th Duc parted out went around the world)
1994 Monster 900 (5th Duc parted out went around the world)
2001 996 (4th Duc Sold)
1999 916 (3rd Duc Sold)
2002 998 (2nd Duc Sold)
1999 R6 (hi-sided at Wilow Spring RIP)
1997 748 (1st Duc sold)
1992 GSXR750 3rd bike (sold)
1986 YZ250 (stolen)
1987 GSXR750 2nd bike (sold)
1986 FZ600 first bike (sold)
