Chain oil mess - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Oil and Lubrication
Old Oct 13th, 2010, 12:09 am   #1 (permalink)
Images: 5
Chain oil mess
I've tried and I can't see any way to oil my chain without making a total mess of my rim and tire. Most modern chain lubes come in an aerosol can so I don't see how. Anybody have any pointers on oiling the chain without getting it all over everything else?
2007 Yellow 1098
"The specific purpose of the desmodromic system is to force the valves to comply with the timing diagram as consistently as possible. In this way, any lost energy is negligible, the performance curves are more uniform and dependability is better."
Alpha is offline   Reply With Quote
Old Oct 13th, 2010, 12:38 am   #2 (permalink)
Go to the "Hall of Wisdom" subforum and start scrolling. There are several threads containing hours and hours of helpful reading material about chain care...
Old Oct 13th, 2010, 1:50 pm   #3 (permalink)
Shazaam's Avatar
Try cutting up a cardboard box to fit in the area behind the chain where you get overspray. The box can be also used to catch any drippings from scrubbing with chain cleaner. Line the box with plastic so you can dispose of the residues properly.
Shazaam is offline   Reply With Quote
Old Oct 13th, 2010, 2:08 pm   #4 (permalink)
Images: 5
Thanks i will try that.
2007 Yellow 1098
Old Oct 18th, 2010, 1:10 pm   #5 (permalink)
TheFrog's Avatar
Images: 17
that's what works for me
Olivier [F1098s Fighter, Monster S2R]
TheFrog is offline   Reply With Quote
Old Oct 18th, 2010, 4:33 pm   #6 (permalink)
Bly
Helmet Haired Hoon
Bly's Avatar
Engine oil on a rag.. and a dry rag to wipe off excess.
Bly is offline   Reply With Quote
Old Oct 31st, 2010, 8:29 pm   #7 (permalink)
make a box peice like an L so you put the bottom on the L (like a 2" lip thing) under the chain and hold onto the top part of the L while it is in turn guarding all your other stuff.
i use this on all my bikes
and also, i use a chain lube thats more of a wax lube that sticks to the chain and dosent spray in such a mist formation,that helped a bunch
DreyeIce is offline   Reply With Quote
Old Nov 11th, 2010, 4:37 pm   #8 (permalink)
bzr
øøøøº
bzr's Avatar
Cut the side out of a 4ltr / 1 gallon container of oil or any other plastic container you have of the same size, when you do, cut from the bottom to just past the point where the sidewall comes in towards the neck of the bottle, continue to cut a square. When you do this the natural shape of the piece has a lip on an angle of about 45 degrees, it's perfect. Best part is you will still be using the same piece in 30 years.
F1098S
This page has had 1221visits! Please stop!!!Seriously!!!!
bzr is offline   Reply With Quote
Old Dec 19th, 2010, 5:20 am   #9 (permalink)
I've been using GoWax for while now. Wipe it on with a rag and there is virtually no throw. Really pleased with it.
10 Streetfighter S black
10 Multistrada S Touring black
07 MV Agusta Brutale 910R
mts1200 is offline   Reply With Quote
Old Mar 29th, 2012, 12:05 am   #10 (permalink)
Jaytron's Avatar
Could you post a link? Google wasn't helpful.
2006 sport1000 MONO: Fatduc, 14t front sprocket
(Sold) 2007 CBR/RR 600
(Sold) 2005 R6
Jaytron is offline   Reply With Quote
Before I mess with it... Dave70 Monster 7 Sep 3rd, 2007 10:54 pm
Well more mess ups... grendels_arm Superbikes 10 Jan 18th, 2007 10:06 am
Did I mess up anything? agora999 Superbikes 14 Apr 14th, 2006 7:07 pm
