Motul oil issue! - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Oil and Lubrication
Old Mar 16th, 2010, 2:17 pm   #1 (permalink)
Sedan_Clan's Avatar
Motul oil issue!
I just recently performed an oil change on my 848 (..from the OEM Shell to Motul) and I am now experiencing clutch slippage. It is occuring in every gear, and is especially noticeable during roll-on at 60-70 mph (..even in 6th gear). Has anybody experienced this issue with Motul before? I'm very unhappy with this product and am considering going back to AMSoil (..which is what I used on my previous bike). Any suggestions? Thanks guys!
BMW ///M Junkie!
Sedan_Clan is offline   Reply With Quote
Old Mar 17th, 2010, 8:58 pm   #2 (permalink)
Stick's Avatar
FWIW, any clutch that slips, will be more noticeable in the highest gear(s). It should slip the least in 1st, and most noticeable in 6th. True for cars, too.
The only way to see if it is the oil is to go back to what you were using.
If that cures the slipping, then you should ask Motul for your $$$'s back.
Stick
Other brands (past):
Old Mar 17th, 2010, 9:31 pm   #3 (permalink)
Red-line's Avatar
Which Motul oil did you use? 5100? 300v?
2009 Ducati 848
Ohlins Supersport FGK 1322 25mm Fork Cartridges w/5mm Upper Extensions | Ohlins TTX | Termi Slip-Ons | Ducabike Rearsets | DP FG Gubellini Damper w/Special 1098 Collar | DP Solo Seat | 1Carbontech HeatGuard / KeyGuard / Fender / Hugger / IntakeRunners | Fabbri Screen | Speedymoto Triple / Frame Sliders | Evoluzione 28mm Slave | ASV levers | Sargent Seat | Oberon Mirror Ext. | Driven 14T Sprocket | Motovation BarEnds / Fork Sliders | Rizoma AVIO-21 signals | Heated Grips wired to Euro Duc999 Controls | DDM 35w 5k HID's | Cox Case / Rad Guards | MotoReva RAM Mount | TechSpec Grips
Red-line is online now   Reply With Quote
Old Apr 14th, 2010, 10:01 am   #4 (permalink)
Images: 2
Try ELF Sport 4 Campione 10W60 or Elf 4 XT Tech 10W50. they are both JASSO MA and you will have no clutch slippage problems.
erikesp is offline   Reply With Quote
Old Apr 14th, 2010, 10:38 am   #5 (permalink)
Red-line's Avatar
I got some Shell Rotella T6 (JASO MA spec!) that I'll be trying at my next oil change.
2009 Ducati 848
Old Apr 15th, 2010, 8:55 pm   #6 (permalink)
As long as the oil doesnt have any friction modifier additives in it, I cant see that affecting the clutch. Any motorcycle specific oil will never have any of the friction modifiers in it. If you look at the back of the bottle where the API label is, if it says "energy conserving" it will have the friction modifiers in it,
that might cause your wet clutch to slip. If it doesnt say that, you are safe
to use that oil in any wet clutch bike.
gg996 is offline   Reply With Quote
Old May 10th, 2010, 5:54 am   #7 (permalink)
kev.'s Avatar
If it's just started from the oil change then you put the wrong oil in!!!!! Motul have a very good product
kev. is offline   Reply With Quote
Old May 13th, 2010, 12:40 pm   #8 (permalink)
Images: 2
The rating you are looking for is the Jasso MA rating on the back of the bottle. If it has this rating then you should have no problems with clutch slippage because of the lubricant.
Performance is a Matter of Choice
Performance Motorcycle Products
Anybody using Mobil 1 5W50 car engine oil ? Yves_atlanta Superbikes 58 Jun 29th, 2010 10:59 pm
Metal Particles on Oil Screen Shazaam Hall of Wisdom 4 Jun 4th, 2010 8:27 am
Oil leak from pushrod... (Slave cylinder side) (1999 900SS) nserdar9119 Supersport 4 Oct 12th, 2009 11:45 pm
