Chain lube - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Oil and Lubrication
Old Feb 23rd, 2009, 8:47 am   #1 (permalink)
Chain lube
Curious to know which chain lube you use and what you like about it. Also, those you no longer use and why. TIA...
BrianSantaRosa is offline   Reply With Quote
Old Feb 23rd, 2009, 3:32 pm   #2 (permalink)
Official Sponsor
Jason@STG's Avatar
i like the repsol chain lube quite a bit. its not too messy and goes on easy. i probably lube my chain more than others, about every three street rides or so. i spray it when the chain is warm. sometimes i put a bit on, wipe all the old stuff off and spray it again before i park it. make sure to spray from behind or on top of the sprocket, as you want to get the o-rings and rollers lubed. a small can of repsol will last quite a while
Jason@STG is offline   Reply With Quote
Old Feb 23rd, 2009, 9:19 pm   #3 (permalink)
macraige
Lately I've been using MFR chain lube on the ST4s & wife's ST3s. Its a thin type lube that does not cause a buildup of black gunk or sling said black gunk all over one's back wheel. Important to put on at the end of the ride when chain is warm, let is sit for a few minutes, then wipe of excess so the chain and sprocket stays clean and there's no thin stuff left to be slung off. Been using for about 3000 miles, so remains to be seen whether will result in any undue wear compared to the sticky thick type lube. Check out the website for this stuff @
http://www.progoldmfr.com/products/chainlube.html
I don't sell anything remotely related to motorcycles, so this is not a commercial. So far, appears to be keeping things lubed and at the same time, chain, sprocket and rear wheel stay fairly clean. Much cleaner than the thick stuff anyway.
Current:
2004 ST4s Senna, Termis, airbox, Race ECU & PCIII.
2004 BMW R1100S BCR, Ohlins & Staintune.
Previous:
1999 BMW R1100S
1997 BMW K1100LT
1975 Honda 750
1970 Kawasaki 500
Several other small bikes from the 60's
macraige is offline   Reply With Quote
Old Feb 24th, 2009, 9:56 pm   #4 (permalink)
Carl's Avatar
Chain lube? What's that?
No, seriously I've been using Honda brand for years with no complaints. My pervious bike, an '05 Yamaha R1 that I bought new, the chain lasted about 19,000 miles with regular cleaning and lubing.
2005 999 Black
2003 Yamaha R6 (track)
2005 Honda CRF250X
2005 Honda S2000
Carl is offline   Reply With Quote
Old Feb 24th, 2009, 11:06 pm   #5 (permalink)
thanks guys for your replies. thus far i've used maxima and motorex... maxima is okay but i'm not sure how well it penetrates, and it does attract gunk in the winter... motorex went on like seminal fluid.... terrible thing to do to a gold chain..
found out i can get repsol at my local cycle gear store, and i used prolink (mfr) on my bicycles for years - good stuff - honda... not sure where to get that....
Old Mar 10th, 2009, 2:51 pm   #6 (permalink)
galaxy's Avatar
Images: 27
Remember these couple of points...Modern day X ring chains are sealed, thus nothing to penetrate into. You don't really need a lube for modern chains. What you need is a wax, and the Maxima is exactly that. It coats and covers the chain keeping the gunk and elements off the surface. Yes, stuff sticks to it, but you're gonna have that no matter what you use and the Maxima is doing its job.
I was a long time Maxima chain wax fan and then I started using Amsoil MPHD. It's almost the exact same stuff (color, consistency, texture, etc) as the Maxima in the gold can, except just a slight bit thinner. At first I didn't like this but the I discovered it works just as well, and it's noticeable easier to clean off come clean up time. So, that's all I use now.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Mar 11th, 2009, 4:27 pm   #7 (permalink)
kaos's Avatar
maxima synthetic,on the road bikes,belray (superclean)on my dirt bikes.the metal on metal of the rollers and sprockets needs more than wax if your serious about wear and hp.that and wax seems to be more work to clean off the chain when trying to keep the stuff looking good
giallo 949- impractical,irrational,irresistible ,09 gasgas raga,11-12 gasgas cervantes 250- all in all ,my version of garage nirvana
kaos is offline   Reply With Quote
Old Mar 15th, 2009, 6:21 pm   #8 (permalink)
superhawk's Avatar
Been useing repsol, gunna try motul and compare
superhawk is offline   Reply With Quote
Old May 18th, 2009, 6:42 pm   #9 (permalink)
CU3RVO's Avatar
Images: 8
I use Chainwax...plus the smell reminds me of the good old NAVY days in Guantanamo.... has that Ammo/new gun smell....num num num
CU3RVO
2006 Monoposto, Yellow...
When asking a Ducati owner if he had any problems with his bike, his response was:
"The only problem I've had is attractive women divesting themselves of their clothing and rubbing their naughty bits on my leg while they lick the gas tank. Makes it hard to pull away from a red light,...... sometimes."
CU3RVO is offline   Reply With Quote
Old May 18th, 2009, 8:53 pm   #10 (permalink)
slhaggard's Avatar
I use the BelRay chain lube. I have used chain wax in the past, but it seems to "gunk" up a bit more. Both are good prodcts, IMHO.
Stephen
Previous 2003 Monster 620 owner. Proud owner of a 2003 ST4s ABS.
  • Ducati Comfort Fairing
  • Sargent Seat
  • 1/2" Bar Risers
  • Penske Rear Shock
  • 15/42T Sprockets
  • Vented Counter-shaft Sprocket Cover from DT
  • DT Case Saver Insert
  • Evo Clutch Slave
  • Billet Reservoir Covers from DT
  • Throttlemeister
  • BMC Air Filter
  • "Full Monty" Barnet Clutch, Hard Ano Basket, Vee-Two Hub from DT
  • Carbon Fiber Sil Motor Exhaust
  • Power Commander III USB (Need some dyno time)
slhaggard is offline   Reply With Quote
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
Chains and oiling duckbrand Superbikes 31 Mar 21st, 2008 2:33 am
748: lube the chain without a rear stand? keef Superbikes 13 Sep 5th, 2007 9:02 pm
