What kind of chain lube do you use? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Oil and Lubrication
Old Nov 7th, 2011, 3:16 pm   #1 (permalink)
Team503's Avatar
2011 Ducati 848 Evoluzione Rossa - Ducati Sport Seat, Termignoni Slip-on Kit
2002 Honda CBR600F4i - Winning Red, now pancake shaped
MSF Grad / AMA Member
It doesn't matter what you ride, just that you ride. -- Psiphor.
Team503 is offline   Reply With Quote
Old Nov 7th, 2011, 3:26 pm   #2 (permalink)
Dennie's Avatar
Since one month I'm using Dupoint lube. Thanks to Porsche Barry!! That lube is superb and it doesn't fly off the chain. However you need to clean the chain very, very good, other wise you will get some lube dust on your wheel.
Dennie is offline   Reply With Quote
Old Nov 7th, 2011, 3:36 pm   #3 (permalink)
Humble
Chuckracer's Avatar
Images: 2
Please follow the link...
Oil and Lubrication - Ducati.ms - The Ultimate Ducati Forum
Old Nov 7th, 2011, 4:15 pm   #4 (permalink)
m54samrr's Avatar
Bel-Ray Super Clean Chain Lube
Use it on my racebike, both streetbikes and on the dirtbike as well. I love it because it never flings off and it makes the chain look like it came straight out of the dealer crate.
Of course you should always follow the cleaning procedures mentioned above before applying
"Racing makes a heroin addiction look like a vague craving for something salty" - Peter Egan
"Power corrupts. Absolute power is kind of neat."
m54samrr is offline   Reply With Quote
Old Nov 7th, 2011, 4:46 pm   #5 (permalink)
Able Duc's Avatar
Can of worms
My process that no one else likes:
If really filthy - Kero first to remove excess gunk and crudd, WD40 to get rid of the kero and polish it up then engine oil on a rag with a very thin coating.
General care - WD40 to kleen it up, then the engine oil just to stop the rust.
A guy just gave me a can of Panolin Bio Chainlube from Switzerland. Followed the label, applied to the chain when it was clean and hot (not a spec of kero or WD40). Now there is shit everywhere!
Back to WD40 - I get long life out of chains.
749 2003 Mono Red with Termi, Carbon Fairings and other bits-GONE
883 2011 Iron Denim Black
1050 2010 Sprint Black
Able Duc is offline   Reply With Quote
Old Nov 7th, 2011, 5:35 pm   #6 (permalink)
m54samrr's Avatar
Originally Posted by Able Duc View Post
Can of worms
I happen to like your process, and it really works...I use the WD40 to remove the moisture from in between the links/x,y,z,o-rings before applying the clean lube stuff. I have moisture and water on the chain after I clean it with a degreaser/water. Kerosene works awesome too...as you said its a can of worms and everyone seems to have their own method though. My chains even on my racebike which sees a large amount of abuse, seem to last a loooong time as long as you love and care for them.
Old Nov 8th, 2011, 11:50 am   #7 (permalink)
DuckMan's Avatar
This is all I use. I get it at Lowe's for about cheap. When I wash the bike I spray the chain and sprockets down with WD40 and let it sit for a few minutes and then hose off followed by Simple Green and hose off again. If I have the power washer out I use it but be carefull of the chain O-rings. After washing I blow the water out of the chain and spray with the lube. Wipe that off and spray again. I do the the spray/wipe/spray maybe every 5-600 miles.
Just his past weekend I pulledy my origional rear sprocket off the Monster to mount a quick change carrier. I've been wanted to play with different gear ratios and this is the easiest and cheapest way to do it. This sprocket has 18100 miles on it. During that time the origional chain has only been adjusted twice. YMMV.
Mike
DuckMan is online now   Reply With Quote
Old Nov 9th, 2011, 7:42 pm   #8 (permalink)
Been using Maxima Chain Wax on all my bikes. Works great and love the fact that there is no fling off
pcguru2k is offline   Reply With Quote
Old Nov 10th, 2011, 12:17 am   #9 (permalink)
freeflydive's Avatar
I have 2x lubricants that I use.
1) Run the bike for a few miles to warm up the chain.
2) Spray "Bel-Ray 6in1" (all purpose lubricant) on a rag to clean off (rust/gunk) the exterior sides of the chain.
3) Spray "Silkolene Pro Chain, Race" (synthetic non-fling) lubricant directly inside the chain to lubricate the O-rings.
4) Let the bike sit for the chain lubricant to set.
Ciao Super Sic!
'12 BMW S1000RR
'09 Ducati 1198
'04 HD VROD (sold)
'03 GSX-R 750 (sold)
freeflydive is offline   Reply With Quote
Old Nov 10th, 2011, 4:09 pm   #10 (permalink)
Check your air pressure!!!
va duc's Avatar
Images: 12
Originally Posted by duckman View Post
this is all i use. I get it at lowe's for about cheap. When i wash the bike i spray the chain and sprockets down with wd40 and let it sit for a few minutes and then hose off followed by simple green and hose off again. If i have the power washer out i use it but be carefull of the chain o-rings. After washing i blow the water out of the chain and spray with the lube. Wipe that off and spray again. I do the the spray/wipe/spray maybe every 5-600 miles.
Just his past weekend i pulledy my origional rear sprocket off the monster to mount a quick change carrier. I've been wanted to play with different gear ratios and this is the easiest and cheapest way to do it. This sprocket has 18100 miles on it. During that time the origional chain has only been adjusted twice. Ymmv.
+1
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Chain lube on your Duc? metalhead Ducati Motorcycle Chat 19 Feb 23rd, 2010 9:17 pm
How do you get the chain lube off?? Gunzen Supersport 25 Oct 31st, 2009 10:47 am
Chain Lube RedDuke999 Superbikes 16 Apr 7th, 2009 7:12 am
Chain Lube... Here we go again! pazzoduc Ducati Motorcycle Chat 10 Jul 1st, 2006 9:29 am
