Sep 27th, 2011, 10:55 am
Oil change mystery, only 2 quarts drained out??
Did an oil change, replaced oil filter and only 2 quarts went back in. That means approx 2 quarts of old oil did not drain! Is there a secret to fully draining the crankcase??
2012 Ducati Monster 796
Sep 27th, 2011, 11:37 am
Check your air pressure!!!
Yes, the bike has to be upright, not on the side stand.
AMA Member
1998 Silver ST2$
Eastern Virginia, USA
Sep 27th, 2011, 12:27 pm
What makes you think that bike holds 4 quarts of oil?? I assure you it does not.
www.ducati-owners-group.com
Sep 27th, 2011, 2:24 pm
Bike was upright on a race stand.
I said "approx". Owners manual says 3.7 Liters or 3.91 quarts. so im off by .09 quart. So yes, I do think the bike holds about 4 quarts.
So, question again, does anyone know why the crankcase does not fully drain??
Sep 27th, 2011, 2:58 pm
Wow...my apologies! I didn't imagine that thing would hold that much. If you've removed the filter, drain plug, and screen (if that motor has one) then that's all that's coming out.
I don't know the numbers off hand, but I do recall the owners manual on my SS is waaaaay off. Bike holds just over 2 quarts.
Sep 27th, 2011, 3:26 pm
My previous ride a yamaha FZ1 holds 4 quarts and exactly 4 quarts goes back in after draining the oil and filter.
If the owners manual on the Duc says 3.91 quarts and only 2 comes out, maybe its getting trapped in the oil cooler?? or maybe I need to rock the bike side to side?
Its a little comforting to know that your SS is doing the same thing, but not too happy knowing that approx 50% of the old oil is now mixed in with the new oil.
My next oil change will be this weekend, Ill try rocking the bike side to side and see if it makes a difference. I did not remove the screen but will on this next change. Hopefully one of the two proposed solutions will yield an answer to this missing oil mystery.
Sep 27th, 2011, 4:43 pm
That's odd, I would re post this in the SS forum, maybe someone there can help you?
AMA Member
1998 Silver ST2$
Sep 28th, 2011, 9:40 am
Did you empty the oil cooler? (If it has one...?)
Sep 28th, 2011, 10:20 pm
Official Sponsor
To get all the oil out you (often) do need to leave it overnight so the oil in the cooler and hoses (and a lot that is just laying in small crevices) can (slowly) drain out.
HTH
Michael Heth
mheth@motolectric.com
Motolectric.com | Innovative Electrical Upgrades For Motorcycles Since 2002 |
Also available through Motolectric | Remus - Melvin - Odyssey - Shorai - Magnecor - Scotts Dampers - Traxxion Fork Upgrades - TFX Custom Shocks |
Sep 29th, 2011, 8:01 am
Yea, but you guys are talking about squeezing blood out of a turnip...ounces; and I'm talking only a few ounces. Not worth removing the oil cooler.
Moral of the story is, you ARE NOT missing/leaving two quarts of oil in the motor. It's empty. The book is incorrect.
