999 Oil Filters - Ducati.ms - The Ultimate Ducati Forum
Go Back   Ducati.ms - The Ultimate Ducati Forum > General Discussion > Oil and Lubrication
Old Mar 11th, 2011, 2:45 pm   #1 (permalink)
DucNutz's Avatar
999 Oil Filters
I found some part numbers for available oilfilters that fit the 999.
• AMSOil SMF 132/132C
• EMGO 10-26980
• Fram PH6019, PH6074
• K&N KN-153
• NAPA 7013
• WIX 57013
I'm sure this isn't all of them if you know of any others, post em up.
DucNutz is offline   Reply With Quote
Old Apr 1st, 2011, 9:27 pm   #2 (permalink)
galaxy's Avatar
Images: 27
I don't know what Amsoil filter you have listed there, but that's not the one you want for a Duc. But to be fair, I am checking with our tech department to see what's up, so I'll post it up when they get back to me. The Correct Amsoil filter is EaOM138C, and if you do a manufacturers search on the web site, this is the one that will come up. Trust me, it's the correct one. They are not just for the 999 either...same filter for just about every Duc ever made.
www.ducati-owners-group.com
galaxy is offline   Reply With Quote
Old Apr 5th, 2011, 3:17 pm   #3 (permalink)
Banned
Harley Davidson actually stocks a brand that is the equivalent to the 996/999 series FRAM for like 8.00 bucks. If you change your oil often, those types shouldn't be a problem.
dv8ryan is offline   Reply With Quote
Mwr filters luca HyperMotard 3 Oct 10th, 2010 7:05 pm
dna air filters? jeremyh007 Superbikes 0 Jul 2nd, 2009 9:50 am
Oil Filters RedDuke999 Superbikes 16 Apr 5th, 2009 12:05 pm
K&N air filters are here!! 08hyper HyperMotard 4 Jun 26th, 2008 11:03 am
Where to buy oil filters tomy2k748 Superbikes 21 Apr 4th, 2007 3:35 am
